BST / BSTPro Dongle BestSmartTools Official Support Section |
08-16-2017, 07:43 | #1 (permalink) |
Junior Member Join Date: Aug 2017
Member: 2747992 Status: Offline Thanks Meter: 0 | Remove ScreenLock Samsung Galaxy Ace I am new in this thing and just got my very first BST dongle yesterday and my test case is to reset forgotten screen lock (pattern lock) from SM-G316HU (Galaxy Ace Style), which is supported by BST device list. I tried Reset ScreenLock button for this, but i get the following error instead of successful unlock FYI, device is attached directly to my laptop with USB cable (not via adapter), and yes, i have allowed USB debugging, and it is recognized by my laptop (Win7Pro x64). Code: Scanning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: Need Read Info Device Info (MTP) Model: SM-G316HU IMEI: 357302060752309 PDA Version: G316HUDXU0AOA4 Phone Version: G316HUDDU0AOA2 CSC : G316HUOLB0AOA3 CSC Version: G316HUDXU0AOA4 SerialNumber: R21G336E7QK Device Info (UART) ... failed Time used : 47.5 s Unlock ... failed to connect device Prepare environment ... Device do not have ADB interface, turn on device USB DEBUG and connect with usb cable,then re-scan device Need reboot device to normal Time used : 56.5 s Did i do this incorrectly? Any advice? Thanks! |
08-16-2017, 09:59 | #3 (permalink) |
Member: 2747992 Status: Offline Thanks Meter: 0 | USB debug is not detected? As i mention earlier, i did enable USB debugging, i even re-attach the device and re-scan as per instructed by the log. The USB cable is working fine though (tested). Is it possible that BST cannot detect USB debugging state from my device? Anyone has experience this before on Win7x64? Thanks! |
08-16-2017, 10:01 | #4 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,804 | i think no issue for 7 64 bit windows u tried flashing twrp recovery so iy will enable usb debug in recovery mode from there do screen unlock in recovery |
08-16-2017, 10:28 | #6 (permalink) |
Junior Member Join Date: Apr 2014 Location: iran-bandar anzali port
Member: 2166383 Status: Offline Thanks Meter: 1 | you can remove this whith out any box . you can writh coustom recovery and flash remove zip file or aroma file manger from it . or remove this whith bmt dangel writh csc file |
