BST / BSTPro Dongle BestSmartTools Official Support Section |
01-08-2015, 19:07 | #1 (permalink) |
Freak Poster Join Date: Dec 2012 Location: Egypt Age: 28
Member: 1857256 Status: Offline Sonork: 1650338 Thanks Meter: 91 | s3 neo i9300i need cert file for repair imei s3 neo i9300i need cert file for repair imei or onter way to repair imei by bst dongle i try but not connect with phone Restarting ADB service ... ok Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: GT-I9300I Hardware: QCOM Mode: normal ----------------------------------------------------- Download: Press Vol Dn + Home + Power UART Cable Resistor: 523 K ReadCodes/Unlock/Repair: 1. Type *#0808# and set USB to AP. 2. Set "USB Settings" to "DM+MODEM+ADB". 3. Click "OK". Cables: MicroUSB Interface: Auto, Change UART when request Read Info/Flashing/UserLock/Backup: Cables: MicroUSB Interface: Auto Detect 1 USB devices not install driver user canceled Connect to device ... Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds but no thing happeng on the phone and the phone full rooted |
The Following User Says Thank You to amh111515 For This Useful Post: |
01-09-2015, 02:17 | #2 (permalink) |
Member: 1857256 Status: Offline Sonork: 1650338 Thanks Meter: 91 | Done using asansam box as com port with rj-45 cable S3 NEO I9300I REPAIR IMEI DONE BY BST Restarting ADB service ... ok Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: GT-I9300I Hardware: QCOM Mode: normal Detect 1 USB devices not install driver Connect to device ... Device Authentication ... Writing IMEI ... Writing IMEI certificate ... ok, You need reboot device Connect to device ... Device Authentication ... Writing IMEI ... Writing IMEI certificate ... ok, You need reboot device Restarting ADB service ... ok Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: GT-I9300I Hardware: QCOM Mode: normal Detect 1 USB devices not install driver Repair 3G network ... done THANKS BST TEAM |
The Following 3 Users Say Thank You to amh111515 For This Useful Post: |
