BST / BSTPro Dongle BestSmartTools Official Support Section |
11-25-2015, 11:27 | #1 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | samsung account how to emove? ----------------------------------------------------- Load EFS "C:\Users\hamid\Desktop\SM-G900F_EFS_RF8F40990FX_2014_05_08_03_03_27.bin" ok Reboot device to DOWNLOAD mode ... Wait device ready ... Connect to device ... Device pit saved to D:\BST\backup\samsung\pit\SM-G900F\SM-G900F_2015-11-25_02.17.04.pit Repair EFS ... Flash completed Time used : 8.6 s Prepare environment ... Device do not have ADB interface, turn on device USB DEBUG and connect with usb cable,then re-scan device Need reboot device to normal Time used : 0.0 s Prepare environment ... Device do not have ADB interface, turn on device USB DEBUG and connect with usb cable,then re-scan device Need reboot device to normal Time used : 0.1 s Restarting ADB service ... ok Scanning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: Need Read Info Detect 1 USB devices not install driver Reboot device to DOWNLOAD mode ... Wait device ready ... Connect to device ... Repair EFS ... Flash completed Time used : 11.3 s Restarting ADB service ... ok Scanning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: Need Read Info Detect 1 USB devices not install driver Device Info (MTP) Model: SM-G900F IMEI: PDA Version: G900FXXU1BNL2 Phone Version: G900FXXU1BNL2 CSC : G900FXEO1BNL1 CSC Version: G900FXXU1BNL2 Time used : 27.1 s Device Info (MTP) Model: SM-G900F IMEI: PDA Version: G900FXXU1BNL2 Phone Version: G900FXXU1BNL2 CSC : G900FXEO1BNL1 CSC Version: G900FXXU1BNL2 Time used : 27.1 s Restarting ADB service ... ok Scanning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: Need Read Info Detect 1 USB devices not install driver Device Info (MTP) Model: SM-G900F IMEI: PDA Version: G900FXXU1BNL2 Phone Version: G900FXXU1BNL2 CSC : G900FXEO1BNL1 CSC Version: G900FXXU1BNL2 Time used : 27.1 s Removing Google Locks (this could take 2-3 minutes) … failed to connect device Prepare environment ... Device do not have ADB interface, turn on device USB DEBUG and connect with usb cable,then re-scan device Need reboot device to normal Time used : 56.6 s |
12-26-2015, 10:02 | #3 (permalink) | |
Freak Poster Join Date: Feb 2013 Location: Where YOu Cant Go Age: 25
Member: 1877938 Status: Offline Sonork: 100.1659358 Thanks Meter: 72 | Quote:
connect phone,scan,select model no.,read info,go in unlocking tab,click on ---> Remove Samsung reactivation lock. All done. | |
12-26-2015, 16:00 | #6 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | Mode: unknown Detect 1 USB devices not install driver Checking environment ... failed Device Info (MTP) Model: SM-G900F IMEI: 352558067456401 PDA Version: G900FXXU1BNL2 Phone Version: G900FXXU1BNL2 CSC : G900FXEO1BNL1 CSC Version: G900FXXU1BNL2 ----------------------------------------------------- Download: Press Vol Dn + Home + Power UART Cable Resistor: 523 K ReadCodes/Unlock/Repair: 1. Type *#0808# and set USB to AP. 2. Set "USB Settings" to "DM+MODEM+ADB". 3. Click "OK". Cables: MicroUSB Interface: Auto, Change UART when request Read Info/Flashing/UserLock/Backup: Cables: MicroUSB Interface: Auto Time used : 1 min 35 s user canceled Time used : 2 min 34 s Can't open port COM21 Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds Time used : 0.1 s Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds Time used : 18.4 s Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds Time used : 18.4 s |
12-27-2015, 09:54 | #7 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | er : BstKey V3.28 Serial : 3C00-E7AA-5F39-70F8 Active User: hamid20 PL2303 : 3.4.48.272 2013-02-05 (OK) Best Smart Tools, Load OK. Restarting ADB service ... ok Scanning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: offline offline Your device is offline, try follow steps to solve this problem: 1. diable and re-enable your device USB debug 2. reboot your device 3. restart adb service 4. change a usb cable or usb port. Detect 1 USB devices not install driver Checking environment ... failed Device Info (MTP) Model: SM-G900F IMEI: 352558067456401 PDA Version: G900FXXU1BNL2 Phone Version: G900FXXU1BNL2 CSC : G900FXEO1BNL1 CSC Version: G900FXXU1BNL2 ----------------------------------------------------- Download: Press Vol Dn + Home + Power UART Cable Resistor: 523 K ReadCodes/Unlock/Repair: 1. Type *#0808# and set USB to AP. 2. Set "USB Settings" to "DM+MODEM+ADB". 3. Click "OK". Cables: MicroUSB Interface: Auto, Change UART when request Read Info/Flashing/UserLock/Backup: Cables: MicroUSB Interface: Auto Time used : 1 min 31 s Reboot device to DOWNLOAD mode ... Reboot device to DOWNLOAD mode ... Reboot device to DOWNLOAD mode ... Reboot device to DOWNLOAD mode ... Checking environment ... failed Device Info (MTP) Model: SM-G900F IMEI: 352558067456401 PDA Version: G900FXXU1BNL2 Phone Version: G900FXXU1BNL2 CSC : G900FXEO1BNL1 CSC Version: G900FXXU1BNL2 Time used : 59.8 s Reboot device to DOWNLOAD mode ... Restarting ADB service ... ok Scanning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: Need Read Info Detect 1 USB devices not install driver Reboot device to DOWNLOAD mode ... Wait device ready ... Unlocking device ... not support this operation |
12-27-2015, 11:54 | #8 (permalink) |
Member: 2325887 Status: Offline Thanks Meter: 134 | Fw.Ver : BstKey V3.28 Serial : 3C00-E7AA-5F39-70F8 Active User: hamid20 PL2303 : 3.4.48.272 2013-02-05 (OK) Best Smart Tools, Load OK. Restarting ADB service ... ok Scanning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: offline offline Your device is offline, try follow steps to solve this problem: 1. diable and re-enable your device USB debug 2. reboot your device 3. restart adb service 4. change a usb cable or usb port. Detect 1 USB devices not install driver Checking environment ... failed Device Info (MTP) Model: SM-G900F IMEI: 352558067456401 PDA Version: G900FXXU1BNL2 Phone Version: G900FXXU1BNL2 CSC : G900FXEO1BNL1 CSC Version: G900FXXU1BNL2 ----------------------------------------------------- Download: Press Vol Dn + Home + Power UART Cable Resistor: 523 K ReadCodes/Unlock/Repair: 1. Type *#0808# and set USB to AP. 2. Set "USB Settings" to "DM+MODEM+ADB". 3. Click "OK". Cables: MicroUSB Interface: Auto, Change UART when request Read Info/Flashing/UserLock/Backup: Cables: MicroUSB Interface: Auto Time used : 1 min 30 s Reboot device to DOWNLOAD mode ... Reboot device to DOWNLOAD mode ... Reboot device to DOWNLOAD mode ... Checking environment ... failed Device Info (MTP) Model: SM-G900F IMEI: 352558067456401 PDA Version: G900FXXU1BNL2 Phone Version: G900FXXU1BNL2 CSC : G900FXEO1BNL1 CSC Version: G900FXXU1BNL2 Time used : 1 min 3 s Reboot device to DOWNLOAD mode ... Restarting ADB service ... ok Scanning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: offline offline Your device is offline, try follow steps to solve this problem: 1. diable and re-enable your device USB debug 2. reboot your device 3. restart adb service 4. change a usb cable or usb port. Detect 1 USB devices not install driver Checking environment ... failed Device Info (MTP) Model: SM-G900F IMEI: 352558067456401 PDA Version: G900FXXU1BNL2 Phone Version: G900FXXU1BNL2 CSC : G900FXEO1BNL1 CSC Version: G900FXXU1BNL2 Time used : 52.1 s Reboot device to DOWNLOAD mode ... Reboot device to DOWNLOAD mode ... Reboot device to DOWNLOAD mode ... Reboot device to DOWNLOAD mode ... Checking environment ... failed Device Info (MTP) ... failed Time used : 0.3 s Restarting ADB service ... ok Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: Hardware: Mode: DOWNLOAD Detect 1 USB devices not install driver Unlocking device ... not support this operation Scanning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: Need Read Info Detect 1 USB devices not install driver Scanning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: Need Read Info Detect 1 USB devices not install driver Reboot device to DOWNLOAD mode ... Wait device ready ... Unlocking device ... not support this operation |
12-27-2015, 13:47 | #9 (permalink) | |
No Life Poster Join Date: Dec 2013 Location: Uzbekistan/Tashkent
Member: 2082192 Status: Offline Sonork: not Thanks Meter: 1,119 | Quote:
SM-G900F Android 5.0 Samsung Account Remove not support this moment. Currently Reset Activation (Samsung Account) Lock works only for S6, S6+, NOTE 5, G9198, A8, G15x, G361x, G531x, G903x, J2, J5, J7, T35x, T55x, T715x, T81x series phone! We will try to improve the solution in future updates. Best Regards GsmBest Team | |
