BST / BSTPro Dongle BestSmartTools Official Support Section |
11-30-2016, 16:43 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,541 | Samsung G530T - Tmobile! Imei And Sn 0 - Any Help? someone - play with this phone, now imei /05 cannot write cert and super imei also? by usb and by uart also! can you pls check where should be problem? Fw.Ver : BstKey V3.33 Serial : ******************** Active User: pradeep_kus PL2303 : 3.4.62.293 2013-10-17 Best Smart Tools, Load OK. Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-G530T Hardware: QCOM Mode: normal ----------------------------------------------------- Download: Press Vol Dn + Home + Power UART Cable Resistor: 523 K ReadCodes/Unlock/Repair: 1. Type *#0808# and set USB to AP. 2. Set "USB Settings" to "DM+MODEM+ADB". 3. Click "OK". Cables: MicroUSB Interface: Auto, Change UART when request Read Info/Flashing/UserLock/Backup: Cables: MicroUSB Interface: Auto user canceled Bypass MSL ... done Connect to device ... Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds Time used : 18.7 s Bypass MSL ... done Connect to device ... Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds Bypass MSL ... done Connect to device ... Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds Time used : 18.5 s Connect to device ... Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds Above log by usb and here is UART log Code: Device Authentication ... communication failed Please check: 1. choose the right port 2. some device UART need re-connect use each 30 seconds user canceled Connect to device ... Device Authentication ... failed with MSL Connect to device ... Device Authentication ... failed with MSL Connect to device ... Device Authentication ... failed with MSL Bypass MSL ... This operation need QCDI interface, setting phone as "Help" tips and connect phone with USB cable. Time used : 0.0 s Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-G530T Hardware: QCOM Mode: normal Bypass MSL ... done Time used : 6.9 s Connect to device ... Device Authentication ... failed with MSL how to capture screen |
12-01-2016, 15:30 | #6 (permalink) | |
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,541 | Quote:
how to do a screenshot on a pc | |
The Following User Says Thank You to pradeep_kus For This Useful Post: |
