BST / BSTPro Dongle BestSmartTools Official Support Section |
03-30-2016, 21:07 | #1 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2308509 Status: Offline Thanks Meter: 1 | Samsung S5 Mini Pattern Lock - SM-G800H not detected I need to remove the pattern lock on a Samsung SM-G800H. I installed the SAMSUNG drivers, but BST Dongle does not detect the phone. there are no drivers suggested in the "Home --> Driver Helper" window. I think the phone might be in PTP mode because of the following symptoms: - When I connect the phone to my PC, Windows sees it as a camera device. - When I connect it to a PC with Samsung Kies installed, the phone is not detected and it says that the connection mode of the phone must be MTP. Is there a way to confirm this if the device is locked? If it is indeed in PTP mode, is there anything I can do (with BST or otherwise) to remove the pattern lock without losing data? |
03-31-2016, 11:52 | #3 (permalink) | |
No Life Poster Join Date: Dec 2013 Location: FRANCE
Member: 2091798 Status: Offline Sonork: 100.1662559 Thanks Meter: 156 | Quote:
Sent from my SM-C101 using Tapatalk | |
The Following User Says Thank You to invaderaze For This Useful Post: |
03-31-2016, 12:56 | #4 (permalink) | |
Member: 2308509 Status: Offline Thanks Meter: 1 | Quote:
03-31-2016, 15:14 | #5 (permalink) | |
Automated tools too doing same procedure Sent from my SM-C101 using Tapatalk | |
