BST / BSTPro Dongle BestSmartTools Official Support Section |
03-03-2016, 10:14 | #2 (permalink) |
No Life Poster Join Date: Jun 2011 Location: pakistan
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | faced same problem before but not replied from team......... http://forum.gsmhosting.com/vbb/f891...lease-2053906/ anything going wronge ...... |
03-05-2016, 09:24 | #3 (permalink) |
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | can anyone explaine how to use 523k cable uart method of bst dongle? may be something doing wrong by me..... where is bst team? 3 days passed but no reply.......? |
03-06-2016, 11:01 | #4 (permalink) |
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | anybody tell me how to operate 523k cable........ i am confusing now a lot. what is going wronge or bad handling by me. any tutorial about how to perform unlock or any other operation by 523k cable. bst team............ |
03-06-2016, 20:09 | #5 (permalink) |
No Life Poster Join Date: Apr 2012 Location: -->Certs+ Sboot
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,318 | Hello, If Android Ver 5.1 & Higher Try This Code Before Connection Uart *#0*# Regards, ---------------------- GsmBest Team |
The Following User Says Thank You to ..::CHAIN::.. For This Useful Post: |
03-07-2016, 07:25 | #6 (permalink) | |
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | Quote:
dial *#0*# now at service menu with multi function test. connect usb 1st and do unlock. after bypass msl connect with uart cable 523k. 1st tried with only sigle uart fbus portion and 2sdly tried both portion usb and uart too but nothing happen good. note: usb setting are set when dial *#0808# check cp dm+modem+adb | |
04-06-2016, 12:42 | #9 (permalink) |
Member: 1602407 Status: Offline Sonork: 100.1648061 Thanks Meter: 360 | |
04-06-2016, 16:55 | #10 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Portugal
Member: 478535 Status: Offline Thanks Meter: 433 | Quote:
Have you tried already put some tape on battery bsi contact and then use uart function? | |
04-07-2016, 11:01 | #11 (permalink) | |
after change interface manually. and read info ok by uart with 523k cable but unlock buttons hide now........? | |
04-07-2016, 11:59 | #13 (permalink) | |
That model is from japan and not aware if it have a different procedure to unlock! Sent from my HTC One using Tapatalk Last edited by Desirat; 04-07-2016 at 12:09. | |
