BST / BSTPro Dongle BestSmartTools Official Support Section |
02-09-2015, 09:41 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: KZ
Member: 349343 Status: Offline Thanks Meter: 32 | SM-G800H super imei failed [ANSWERED] Code: Сканирование устройства ... 1 готово dev[1] Производитель: SAMSUNG Moдель: SM-G800H Железо: QCOM Режим: normal На найденное 1 USB устройство драйвера не установлены Подготовка действий ... Бэкап EFS ... D:\BST\backup\samsung\efs\SM-G800H\EFS_samsung_SM-G800H_3553-----------_2015-02-09_14.39.55.efs ok Wiping EFS ... ok Время использования : 16.3 с Подключение устройства ... Аудентификация устройства ... 1 MSL с ошибкой |
02-09-2015, 09:46 | #2 (permalink) | |
Product Manager Join Date: Apr 2005 Location: China
Member: 133050 Status: Offline Thanks Meter: 6,440 | Quote:
Dont forget reboot phone after "Wipe EFS", and then repair imei. will be worknig sure. Best Regards GsmBest Team | |
The Following User Says Thank You to EmeGSM-Wei For This Useful Post: |
02-09-2015, 10:16 | #4 (permalink) | |
Member: 349343 Status: Offline Thanks Meter: 32 | Quote:
Code: Fw.Ver : BstKey V3.21 Serial : 0000-0000-0000-0000 Active User: turboxxx PL2303 : 2.0.13.130 2009-11-19 Best Smart Tools, Load OK. ----------------------------------------------------- Download: Press Vol Dn + Home + Power UART Cable Resistor: 523 K ReadCodes/Unlock/Repair: Cables: MicroUART Interface: Auto, Change UART when request Read Info/Flashing/UserLock/Backup: Cables: MicroUSB Interface: Auto Restarting ADB service ... ok Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-G800H Hardware: QCOM Mode: normal Detect 1 USB devices not install driver Prepare environment ... Backup EFS ... D:\BST\backup\samsung\efs\SM-G800H\EFS_samsung_SM-G800H_350000000000_2015-02-09_15.08.19.efs ok Wiping EFS ... ok Time used : 10.9 s Connect to device ... Device Authentication ... 1 failed with MSL Device Info (UART) Model: SM-G800H SW Version: G800HXXU1ANGF Customer Code: SKZ Unique Number: C16040B9B624381 Flash Memory: - Chipset : true Time used : 2.3 s | |
02-09-2015, 10:21 | #5 (permalink) | |
Contact me with my SKYPE ([email protected]) please, i will remote check and solve problem sure. Best Regards GsmBest Team | |
The Following 3 Users Say Thank You to EmeGSM-Wei For This Useful Post: |
02-10-2015, 01:01 | #6 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 333519 Status: Offline Sonork: 100.1620327 Thanks Meter: 16 | failed same problem here connect to device ... Device Authentication ... Writing IMEI ... Writing IMEI certificate ... failed Connect to device ... Device Authentication ... Writing IMEI ... Writing IMEI certificate ... failed thanks |
02-10-2015, 05:32 | #8 (permalink) |
No Life Poster Join Date: Apr 2012 Location: -->Certs+ Sboot
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,320 | Hello, 1st Wipe Cache & Wipe data In Recovery Then Reboot Phone. Then Scan & Wipe Efs Several Times Hope You Will Done ....... Regards, ------------------ GsmBest Team |
02-13-2015, 17:24 | #10 (permalink) |
Major Poster Join Date: Jul 2013
Member: 1973611 Status: Offline Thanks Meter: 5 | I erased efs z3x box, only it turned out to erase, then I hooked up the phone without secondary contact to the bst through uart, he wrote me a new imei but not recorded cert issued by mistake, in the end I have a new phone with imei but without cert, now it does not catches network, efs fusion bst it does not record. but in the folder bst I found these 3 super imei folder sm G800F !!! I think this cert on the model G800F and we G800H !!! |
02-20-2015, 15:30 | #13 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Russia Age: 47
Member: 372750 Status: Offline Thanks Meter: 77 | You marked this tread: (Answered). But you did not describe how to restore IMEI. If i erased IMEI in z3x(your box not erase), after recording new IMEI was to register on the network.How to record IMEI2 in phone? Describe in detail or not deceive your users to support this operation. B.R. Last edited by TriddicK; 02-20-2015 at 15:35. |
The Following User Says Thank You to TriddicK For This Useful Post: |
