BST / BSTPro Dongle BestSmartTools Official Support Section |
07-24-2015, 16:44 | #1 (permalink) |
No Life Poster Join Date: Apr 2015
Member: 2385655 Status: Offline Thanks Meter: 99 | SM-G920I lock how to remove Scanning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: offline offline Your device is offline, try follow steps to solve this problem: 1. diable and re-enable your device USB debug 2. reboot your device 3. restart adb service 4. change a usb cable or usb port. Detect 1 USB devices not install driver Checking environment ... failed Device Info (MTP) Model: SM-G920I IMEI: 359878062303132 PDA Version: G920IDVU1AOD1 Phone Version: G920IDVU1AOD2 CSC : G920IKSA1AOCE CSC Version: G920IDVU1AOD1 Time used : 43.3 s Restore ... failed to connect device Prepare environment ... Need reboot device to normal Time used : 56.7 s Removing Google Locks (this could take 2-3 minutes) … failed to connect device Prepare environment ... Need reboot device to normal Time used : 56.7 s ---------------------------------------------------- We strongly recommend backup userdata before unlock Google Account Lock Some device can't boot to system after unlock Google Account Lock , execute Factory Reset or enter Recovery Mode,Wipe userdata could fix this. ---------------------------------------------------- Start Read Phone Info ... Need reboot device to normal Time used : 0.0 s Start Read Phone Info ... Need reboot device to normal Time used : 0.0 s Checking environment ... failed Device Info (MTP) Model: SM-G920I IMEI: 359878062303132 PDA Version: G920IDVU1AOD1 Phone Version: G920IDVU1AOD2 CSC : G920IKSA1AOCE CSC Version: G920IDVU1AOD1 Time used : 37.2 s Removing Google Locks (this could take 2-3 minutes) … failed to connect device Prepare environment ... Need reboot device to normal Time used : 56.7 s |
07-26-2015, 05:46 | #2 (permalink) |
Insane Poster Join Date: Jan 2007 Location: egypt . cairo Age: 44
Member: 425239 Status: Offline Thanks Meter: 55 | 1- OneKey Recovery 2- chose your recovery 3- Ok 4- Unlock Via Recovery Mode 5-Unlock |
The Following 2 Users Say Thank You to mahamehonana For This Useful Post: |
