BST / BSTPro Dongle BestSmartTools Official Support Section |
09-07-2016, 18:48 | #1 (permalink) |
Freak Poster Join Date: Apr 2016 Location: Republic Of South Africa Age: 27
Member: 2562560 Status: Offline Thanks Meter: 56 | SM-J500F Super IMEI Write Problem [SOLVED] Code: Scanning devices ... 1 found dev[1] Manufactory: SAMSUNG Model: SM-J500F Hardware: QCOM Mode: normal Connect to device ... Device Authentication ... failed with MSL |
09-07-2016, 18:57 | #2 (permalink) |
Major Poster Join Date: Oct 2015
Member: 2479721 Status: Offline Thanks Meter: 6 | 1. Flash with repair firmware 2. Root with cf auto root 3. In bst after scan wipe efs 4. Write default efs 5. Cover battery bsi line with tape or other things 6. Write super imei with uart 7. Write QCN...... Done. Sent from my SM-G925F using Tapatalk |
09-08-2016, 08:01 | #6 (permalink) |
Junior Member Join Date: Mar 2016
Member: 2552624 Status: Offline Thanks Meter: 1 | 1- downloaded j500f combination file best spot 2- after flash dail *#0808# selected last option 3- click bypass msl 4- write super imei 5- write qcn download qcn best spot 6- and flash with latest 6.0 version _--------------------job done ---------------------- |
The Following User Says Thank You to manishmalik1997 For This Useful Post: |
09-08-2016, 13:01 | #7 (permalink) |
Freak Poster Join Date: Feb 2013 Location: Where YOu Cant Go Age: 25
Member: 1877938 Status: Offline Sonork: 100.1659358 Thanks Meter: 72 | (COMBINATION_OXA_FA51_J500FXXU1AOI2.bsp) download this from bst server and flash to your phone using bst dongle.then retry tested on many many J500f..good luck |
09-09-2016, 08:40 | #8 (permalink) | |
No Life Poster Join Date: Apr 2012 Location: -->Certs+ Sboot
Member: 1753928 Status: Offline Sonork: 100.1615906 Thanks Meter: 2,318 | Hello, Guys Check This Thread Carefully & Follow Step By Step http://forum.gsmhosting.com/vbb/f891...nside-2098505/ Quote:
Regards, _________ | |
09-09-2016, 20:50 | #9 (permalink) | |
Member: 2562560 Status: Offline Thanks Meter: 56 | Quote:
Thanks Mr Chain My Problem Solved | |
