BST / BSTPro Dongle BestSmartTools Official Support Section |
08-27-2014, 15:22 | #1 (permalink) |
No Life Poster Join Date: Jan 2013 Location: HUAWEI FRP KEY imei-code
Member: 1870489 Status: Offline Sonork: 100.1663831 Thanks Meter: 483 | Stock Rom Solve By BST ecently installed a few new ROMs on my Samsung Galaxy S4 and, foolishly, did not make a backup of my stock ROM. I found that all of the ROMs I used (CyanogenMod, SlimKat, and OmniROM) would not let my phone use 4G LTE service and I ended up having a lot of problems with even 3G service. So I decided to re-flash my S4 with the stock ROM, a process I thought would have been trivial. Instead, I found that going back to the old stock ROM wasn’t as easy as I thought and I struggled to find answers to some of the error messages I was seeing. The two that caused the most headache were the “FAIL (auth)” error and the “SW REV CHECK FAIL” error. These errors indicate that the phone cannot use the ROM provided (via Samsung’s ODIN loader) because the ROM is either not legitimate or is a version prior to the one currently installed. Basically, if you’ve flashed a ROM that is Android 4.4.2 (KitKat), you will not be able to revert back to an earlier version (such as Android 4.2.2). The solution is the find the authentic ROM for the same version you’re already at. In my case, I needed KitKat and wanted the official stock ROM. SW REV CHECK FAIL” Solve by BST Load PIT "C:\Documents and Settings\user\My Documents\Downloads\adonis.pit" ok Load BOOT "H:\Z3X\I9500XXUBMEA_OXEBME1\I9500XXUBMEA_OXEBME1\ BOOTLOADER_I9500XXUBMEA_768420_REV00_user_low_ship .tar.md5" ok Load PDA "H:\Z3X\I9500XXUBMEA_OXEBME1\I9500XXUBMEA_OXEBME1\ CODE_I9500XXUBMEA_768420_REV00_user_low_ship.tar.m d5" ok Load Phone "H:\Z3X\I9500XXUBMEA_OXEBME1\I9500XXUBMEA_OXEBME1\ MODEM_I9500XXUBMEA_REV01_CL1331687_SIGNED.tar.md5" ok Load CSC "H:\Z3X\I9500XXUBMEA_OXEBME1\I9500XXUBMEA_OXEBME1\ CSC_OXE_I9500OXEBME1_20130530.142348_REV00_user_lo w_ship_MULTI_CERT.tar.md5" ok Scanning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: Detect 1 USB devices not install driver Scanning devices ... 1 found dev[1] Manufactory: Model: Hardware: Mode: DOWNLOAD Detect 1 USB devices not install driver Flash device with safe flash options Device pit saved to D:\BST\backup\samsung\pit\GT-I9500\GT-I9500_2014-08-27_16.42.30.pit Time used : 9 min 4 s now set ok for me tnx BST TEAM |
