BST / BSTPro Dongle BestSmartTools Official Support Section |
03-10-2014, 09:07 | #1 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Pescara, Italy
Member: 2141071 Status: Offline Sonork: 100.1653717 Thanks Meter: 15 | Trouble with PL2303 Driver[SOLVED] I've installed the last correct driver from Prolific And Windows install it correctly but BST doesn't show me "OK" on the Prolific line at start. Is this a problem for correctr working of the box? This is what i see: PL2303 : 3.4.62.293 2013-10-25 It's ok anyway? P.S. Thank you for your support and your work . Last edited by EmeGSM-Wei; 03-13-2014 at 15:36. Reason: SOLVED |
03-10-2014, 09:40 | #2 (permalink) |
Member: 2141071 Status: Offline Sonork: 100.1653717 Thanks Meter: 15 | No way....everything goes on but when BST ask me to insert uart cable to phone always show "no phone" or something like that...... |
03-10-2014, 10:15 | #3 (permalink) |
Product Manager Join Date: Apr 2005 Location: China
Member: 133050 Status: Offline Thanks Meter: 6,490 | Hi, Install BST as follow way please. http://forum.gsmhosting.com/vbb/f891...tions-1721478/ Tips: Install our PL2303 drivers better, it will working sure. Best Regards GsmBest Team |
The Following User Says Thank You to EmeGSM-Wei For This Useful Post: |
03-10-2014, 12:24 | #5 (permalink) |
Member: 2141071 Status: Offline Sonork: 100.1653717 Thanks Meter: 15 | ...another time same error...while ask me to connect to uart cable it say "can't connect to device,please check the cable connection communication failed" After that i've noticed than in the phone the CP was not show when i write *#1234#.. Only AP and CSC...but before all the operation all was regulary shown... AP CP CSC I've tried to flash only "modem" file with odin and complete the operation and the uart cable now works...Imei ok and also SN but the telephone don't take line and don't make call :S. Last edited by ceatele; 03-10-2014 at 12:32. |
03-10-2014, 12:57 | #6 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2064138 Status: Offline Thanks Meter: 1 | I can't get "OK" in PL2303. I tried to re-install program and driver and still nothing. What I need to do now ? Fw.Ver : BstKey V3.09 Serial : A022-XXXX-XXXX-XXXX Active User: pRo_lama PL2303 : 3.4.62.293 2013-10-25 Best Smart Tools, Load OK. UsbKey: A022-xxxx-xxxx-xxxx Boot: Usb Key BL V1.22 Connect to server .... ok Update firmware step1 ... ok Update firmware step2 ... ok Finish update .... ok @phablet |
03-10-2014, 15:54 | #7 (permalink) |
Member: 2141071 Status: Offline Sonork: 100.1653717 Thanks Meter: 15 | First remove the driver installed for prolific usb serial port...restart pc....when ask to search in windows update say "no" after that install driver from BST server ver 1.8.0. After that restart pc. For me it works. |
03-11-2014, 09:51 | #8 (permalink) | |
Member: 2141071 Status: Offline Sonork: 100.1653717 Thanks Meter: 15 | Quote:
Any solution for this trouble? Model : GTI9300 Firmware stock 4.3 ITV. Last edited by ceatele; 03-11-2014 at 09:57. | |
