Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BST / BSTPro Dongle
BST / BSTPro Dongle BestSmartTools Official Support Section
Old 06-25-2016, 12:40   #16 (permalink)
Member: 1456426
Sonork: 100.1625000
Thanks Meter: 104
Fw.Ver : BstKey V3.30
Serial : 3C9C-EDF4-5E39-70EF
Active User: wasimrahman08
PL2303 : NULL
Best Smart Tools, Load OK.
Scanning devices ... 1 found
dev[1]
Manufactory: SAMSUNG
Model:
Hardware:
Mode: DOWNLOAD
Download: Press Vol Dn + Home + Power
UART Cable Resistor: 523 K
ReadCodes/Unlock/Repair:
1. Type *#0808# and set USB to AP.
2. Set "USB Settings" to "DM+MODEM+ADB".
3. Click "OK".
Cables: MicroUSB
Interface: Auto, Change UART when request
Read Info/Flashing/UserLock/Backup:
Cables: MicroUSB
Interface: Auto
Load PDA "E:\COMBINATION_OXA_FA51_J500FXXU1AOI2.bsp" ok
load pit from files ...
Connect to device ...
Device pit saved to E:\BST\backup\samsung\pit\SM-J500F\SM-J500F_2016-06-25_04.19.21.pit
re-partition ...
Write file aboot.mbn ...
Write file boot.img ...
Write file cache.img.ext4 ...
Write file hyp.mbn ...
Write file modem.bin ...
Write file non-hlos.bin ...
Write file persdata.img.ext4 ...
Write file persist.img.ext4 ...
Write file recovery.img ...
Write file rpm.mbn ...
Write file sbl1.mbn ...
Write file sec.dat ...
Write file system.img.ext4 ...
Write file tz.mbn ...
Flash completed
Time used : 2 min 15 s
dev[1]
Model: SM-J500F
Hardware: QCOM
Mode: normal
dev[1]
Model: SM-J500F
Hardware: QCOM
Mode: normal
Checking environment ...
System Info
Display ID: LMY48B
System Ver: 5.1.1 REL
API Level: 22
Incremental: FA51_J500FXXU1AOI2
Model: SM-J500F
Brand: samsung
Device: j5lte
Platform: msm8916
Language: en
Rigion: GB
Device Info
SerialNumber: 3f1f45d8
Hardware: qcom
Model: j5lte
PDA Version: FA51_J500FXXU1AOI2
Phone Version: J500FXXU1AOH2
Bootloader ver: FA51_J500FXXU1AOI2
Ril HW ID:
Sales Code:
Model ID:
Get Bluetooth info failed
Get WI-FI info failed
Root Access: No root
Time used : 2.6 s
Device Authentication ... 1 failed with MSL
1 failed with MSL
1 failed with MSL
Device Info (UART)
Model: SM-J500F
SW Version: FA51_J500FXXU1AOI2
Customer Code: INU
Unique Number: CR8003F1F45D8B1
Flash Memory: -
Chipset : true
Key ID : 0338
Time used : 1.2 s
Bypass MSL ... This operation need QCDI interface, setting phone as "Help" tips and connect phone with USB cable.
Time used : 0.0 s
Time used : 0.0 s
Device Info (UART)
Model: SM-J500F
Customer Code: INU
Flash Memory: -
Chipset : true
Key ID : 0338
Time used : 1.1 s
1 failed with MSL
1 failed with MSL
Time used : 0.0 s
Time used : 0.0 s
dev[1]
Model: SM-J500F
Hardware: QCOM
Mode: normal
System Info
Display ID: LMY48B
API Level: 22
Model: SM-J500F
Brand: samsung
Device: j5lte
Platform: msm8916
Language: en
Rigion: GB
Device Info
Hardware: qcom
Model: j5lte
Ril HW ID:
Sales Code:
Model ID:
Time used : 2.0 s
Prepare environment ... need root access
Start Get Root ... will try 6 methods
Root with psneuter ... failed
Root with root1 ... failed
Root with exynos-abuse ... failed
Root with root2 ... failed
Root with zergRush ... .failed
Root with BST_SamRoot ... failed
Failed to get root access
Backup EFS ... E:\BST\backup\samsung\efs\SM-J500F\EFS_samsung_SM-J500F__2016-06-25_04.31.55.zip ok
Wiping EFS ... ok
Reboot device to NORMAL mode ...
Re-scan device before any operation please
Time used : 35.1 s
Device Authentication ... communication failed
Please check:
1. choose the right port
2. some device UART need re-connect use each 30 seconds
Please check:
Device Info (UART)
Model: SM-J500F
Customer Code: INU
Flash Memory: -
Time used : 32.8 s
Device Info (UART) ... failed
Time used : 0.0 s
Time used : 0.1 s
Time used : 0.0 s
Time used : 8.9 s
Time used : 0.1 s
Scanning devices ... 0 found
dev[1]
Model: SM-J500F
Hardware: QCOM
Mode: normal
System Info
Display ID: LMY48B
API Level: 22
Model: SM-J500F
Brand: samsung
Device: j5lte
Platform: msm8916
Language: en
Rigion: GB
Device Info
Hardware: qcom
Model: j5lte
Ril HW ID:
Sales Code:
Model ID:
Root Access: ROOTED
Time used : 2.0 s
Writing IMEI ...
Writing IMEI certificate ... ok, You need reboot device
Writing IMEI ...
Old 06-26-2016, 18:59   #17 (permalink)
..::CHAIN::..'s Avatar
Member: 1753928
Sonork: 100.1615906
Thanks Meter: 2,318
Originally Posted by hassamnaseer View Post
Can some one conform that this super imei is working with mothad because I have write this imei but the phone show no service with and without simcard while I also have write the QCN file from working phone but still Same
I want to confirm that by flashing with the combination file and after writing super imei will it work perfectly
Or is there any other solution
When I checked at *#0011# imei cert was fail
Please team help me
Hello,
Yes Bro It Will Done Surely After S.Imei .... Bcz Your Cert Status - FAIL
Regards,
_______________
GsmBest Team
Old 07-01-2016, 15:02   #18 (permalink)
Member: 317483
Thanks Meter: 5
hi how to put qcdi mod ..?
Old 07-05-2016, 08:58   #19 (permalink)
Member: 1753928
Sonork: 100.1615906
Thanks Meter: 2,318
Hello,
When u Select Models For Operation You Can See Instructions In Your Screen
Dial *#0808# --> DM+MODEM+ADB ----> Usb - AP
Regards,
___________
GsmBest Team
Old 07-19-2016, 13:49   #20 (permalink)
Member: 1834175
Thanks Meter: 52
Just downgrade modem ..
Old 07-20-2016, 19:40   #21 (permalink)
rasid310's Avatar
Member: 1467586
Thanks Meter: 80
thank u sir good salution
Old 07-21-2016, 08:52   #22 (permalink)
Member: 2114706
Thanks Meter: 36
can some one help me here also about to write cert on J 500H dual sim
am facing problem urat connection here
Bst team waiting for ur answer
Old 07-21-2016, 12:01   #23 (permalink)
Member: 2598914
I will try this tutorial out soon, thank you for posting
Old 08-14-2016, 07:56   #24 (permalink)
imran78669's Avatar
Member: 1016083
Thanks Meter: 103
it is strange that i follow idea to write super ime but in the end after battery preparation for msl Urt port working but facing error Msl failed.if battery not prepare for msl then communication error.
also flash with full pack .
Old 08-29-2016, 16:55   #25 (permalink)
Member: 2618024
where is the support? how to take from support
Old 08-31-2016, 07:37   #26 (permalink)
Member: 1753928
Sonork: 100.1615906
Thanks Meter: 2,318
Hello,
Select Model & click On Download Rom You Will Get Support . Now Choose COMBINATION Folder & Download J500F Combination...
Regards,
___________
GsmBest Team
Old 09-09-2016, 06:23   #27 (permalink)
GTECH MOBILE's Avatar
Member: 1343470
Thanks Meter: 64
plssssssssssss post combination file ...........
@chain
Old 09-09-2016, 08:37   #28 (permalink)
Member: 1753928
Sonork: 100.1615906
Thanks Meter: 2,318
@chain
Hello,
You Can Take from Support Area !! Good Luck
Regards,
__________
The Following User Says Thank You to ..::CHAIN::.. For This Useful Post:
Old 09-09-2016, 18:12   #29 (permalink)
hari.manju's Avatar
Member: 2050872
Thanks Meter: 658
Dear sir your server is very slow please upload in Google drive please..
Old 09-10-2016, 07:04   #30 (permalink)
Member: 1753928
Sonork: 100.1615906
Thanks Meter: 2,318
Thumbs up J500F Eng ROM External link
Hello,
Here Your Requested Firmware !!
COMBINATION_OXA_FA51_J500FXXU1AOI2_2 - Download - 4shared
Regards,
__________
GsmBest Team
The Following 3 Users Say Thank You to ..::CHAIN::.. For This Useful Post:
Page generated in 0.24670 seconds with 8 queries
