BST / BSTPro Dongle BestSmartTools Official Support Section |
03-17-2017, 10:38 | #2 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Romania Age: 37
Member: 120579 Status: Offline Thanks Meter: 182 | The steps I`m taking are the following: 1. Scan the device (It is rooted). Then info 2. I check "execute "Bypass MSL". I check COM Port 3. I push the Unlock button. Can`t connect to the usb-to-serial comm port, with the error from above. |
03-17-2017, 15:04 | #6 (permalink) |
Member: 120579 Status: Offline Thanks Meter: 182 | So I put the 100k resistor like here: http://forum.gsmhosting.com/vbb/10396754-post1.html Still can`t connect to g925f |
03-19-2017, 19:41 | #10 (permalink) |
Freak Poster Join Date: Oct 2014
Member: 2277857 Status: Offline Thanks Meter: 68 | If you have a removable battery, try this, it works BST-Samsung Note4 N910x_G901x_G850x_G800x UART communication enable! - Support - GsmBest Team |
03-20-2017, 18:15 | #14 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Or If have GPG UART Cable with Switcher Resistor set to 619K and will see that work fine. Both Option working Fine in UART Modality | |
The Following User Says Thank You to allumts For This Useful Post: |
