BST / BSTPro Dongle BestSmartTools Official Support Section |
01-22-2014, 22:39 | #1 (permalink) |
Freak Poster Join Date: Jan 2013
Member: 1870650 Status: Offline Thanks Meter: 12 | Unlock Failed i747 help [ANSWERED] I tried to unlock i337 from AT&T... your instruction show me type *#7284# and choose USB Diag -> but there's no USB Diag and type *#197328640#, select : Common -> Diag Config -> USB Diag...but there's no Common tap. So, I type *#0808# choose DM + Modem + ADB and tried to unlock...but result is failed. here's log... Scanning devices ... 2 found dev[1] Manufactory: Model: Hardware: Mode: offline offline Your device is offline, try follow steps to solve this problem: 1. diable and re-enable your device USB debug 2. reboot your device 3. restart adb service 4. change a usb cable or usb port. dev[2] Manufactory: SAMSUNG Model: SGH-I747 Hardware: Mode: QCDI,MTP Unlocking device ... not supported modem firmware Time used : 1.2 s |
01-23-2014, 10:22 | #3 (permalink) | |
Junior Member Join Date: Jan 2014 Location: In Your smartphone.
Member: 2102900 Status: Offline Thanks Meter: 4 | Quote:
This is what i did exactly ====Flashed my S4 M919 [ tmobile us S4 ] back to 4.2.2 stock ====Rooted using CF Auto root ====Turn on Debugging and approved ====I went to *#0808# and selected DM + MoDEM + ADB last option ====Then *#9090# and selected DM/DUM over HSIC then restart ====Plugged phone back to Computer Using Micro USB only ====Smart tool Samsung Tab Unlock Clicked on Com Port option [ and ====selected port phone was installed on ] ====Then pressed unlock phone restarted and after 10 sec it was unlocked ====T-Mobile s4 using it on AT&T at this moment | |
01-24-2014, 11:46 | #4 (permalink) | |
No Life Poster Join Date: May 2012 Location: Insite IC
Member: 1757379 Status: Offline Sonork: no need Thanks Meter: 400 | Quote:
yes rj45 with 512 k and unlock with urt 100% | |
01-24-2014, 19:11 | #5 (permalink) |
Member: 1870650 Status: Offline Thanks Meter: 12 | I don't have 512k cable...I have only 150k, 619k, 523k and a P1000 cable only...it's all comes with the dongle...when I bought BST dongle I need to buy separate? Let me know.... And when I connect PCB board and phone...computer never recognize the phone...how can I connect it? it dependant on cable? all the drivers are install correctly... |
07-15-2014, 00:35 | #6 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2222469 Status: Offline Thanks Meter: 0 | Anyone can explain me, how to unlock sgh-m919 tmobile, it has 4.3 android version, im trying but I cant do it, im dont know if i will use de UART cable, or only the usb cable, Please help mee!! |
07-15-2014, 04:02 | #7 (permalink) | |
Product Manager Join Date: Apr 2005 Location: China
Member: 133050 Status: Online Thanks Meter: 6,491 | Quote:
Best Regards GsmBest Team | |
12-03-2014, 00:02 | #8 (permalink) | |
Freak Poster Join Date: May 2014
Member: 2184321 Status: Offline Thanks Meter: 9 | Quote:
How you downgrade to 4.2.2 without customizing the 4.4 bootloader? Odin will no let you downgrade and send you to download mode. Pls explain all how you downgrade 4.4 to stock 4.2.2 | |
