BST / BSTPro Dongle BestSmartTools Official Support Section |
10-31-2018, 22:22 | #1 (permalink) |
Junior Member Join Date: Jan 2018
Member: 2804852 Status: Offline Thanks Meter: 0 | xiaomi redmi 5a imei repair NV550 error cant change it Reading IMEI1 ... OK Reading IMEI2 ... OK Reading MEID1 ... Failed (NV1943: Variable was not active) Writing Device Info ... Writing IMEI1 ... Failed (NV550: Parameter is write-protected and thus read only) so icant change this imei. as i live in turkey they want tax to register imei to be able use here. i want to change... but no luck with this dongle. any help pls? |
11-08-2018, 16:43 | #2 (permalink) |
Insane Poster Join Date: Aug 2018
Member: 2855925 Status: Offline Thanks Meter: 62 | if your phone is bootloader unlocked read qcn and use rbsoft to inject imei into qcn read nvm then erase nvm write imei using bst(same as the one you used in rsbsoft) write injeted qcn via bst reboot imei should be repaired now BR |
02-03-2019, 15:26 | #3 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: gsm hosting
Member: 907098 Status: Offline Sonork: 100.1601140 Thanks Meter: 705 | Quote:
its bootloder locked | |
