07-15-2015, 21:51 | #1 (permalink) |
No Life Poster Join Date: May 2012 Age: 27
Member: 1764566 Status: Offline Sonork: SUSPENDED Thanks Meter: 5,763 | GSM Aladdin Key V2 Released Ver 1.22 Huawei Add & Spd 7730/31 Added (16th July 2015) |
The Following 4 Users Say Thank You to IMRAN_ANSARI For This Useful Post: |
07-19-2015, 11:10 | #3 (permalink) |
No Life Poster Join Date: Jan 2013 Location: searching........ Age: 38
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | Samsung E1200Y Read Phone Lock Done By Gsm Aladdin Key V2 Samsung E1200Y Read Phone Lock Done By Gsm Aladdin Key V2 Br Gsm Aladdin Team |
07-20-2015, 17:17 | #4 (permalink) |
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | intex Aqua X5 Mt6572 Clear Privacy Lock Done By Gsm Aladdin Key V2 intex Aqua X5 Mt6572 (Nand Cpu New Flash id) Clear Privacy Lock After Hang On Logo Solve Only Format By Gsm Aladdin Key V2 |
The Following User Says Thank You to jkmobile53 For This Useful Post: |
07-21-2015, 07:56 | #6 (permalink) |
Member: 1764566 Status: Offline Sonork: SUSPENDED Thanks Meter: 5,763 | Micromax a76 pinlock direct removed no data loss no need adb MICROMAX A76 PINLOCK DIRECT REMOVED NO DATA LOSS NO NEED ADB GSM ALADDIN KEY V2' |
The Following 2 Users Say Thank You to IMRAN_ANSARI For This Useful Post: |
07-22-2015, 08:42 | #7 (permalink) |
Member: 1868800 Status: Offline Sonork: 100.1625792 Thanks Meter: 2,344 | Wing W40 Hang On Logo Solved Only Format By Gsm Aladdin Key V2 Wing W40 Hang On Logo Solved Only Format without Any Risk By Gsm Aladdin Key V2 Gsm Aladdin Team |
07-22-2015, 08:51 | #8 (permalink) |
No Life Poster Join Date: Dec 2007 Location: INDIA _ TAMILNADU _ KUMBAKONAM
Member: 667142 Status: Offline Sonork: +919655528882 Thanks Meter: 2,495 | Huawei Ascend Y511-U30 Pattern Lock Code Read Done Huawei Ascend Y511-U30 Pattern Lock Code Read Done Usb Debugging Not Enable Use Factory Mode Only Without Loss Any Data Simple Method ( We Always Care Our Users ) .:: BY ::. ..::: GSM ALADDIN KEY V2 :::.. Hold Volume Up Connect Usb ( Root With Factory Mode ) Reading Pattern Code ( Factory Mode ) Very Simple .: BR :. ..:: [ S V ] ::.. ..::: GSM ALADDIN TEAM :::.. |
The Following 2 Users Say Thank You to ATHI For This Useful Post: |
07-22-2015, 09:30 | #9 (permalink) |
Member: 667142 Status: Offline Sonork: +919655528882 Thanks Meter: 2,495 | Micromax Bolt A28 Google Lock Remove Done Micromax Bolt A28 Google Lock Remove Done With Fastboot Mode .:: BY ::. ..::: GSM ALADDIN KEY V2 :::.. .: BR :. ..:: [ S V ] ::.. ..::: GSM ALADDIN TEAM :::.. |
