01-18-2017, 17:05 | #3 (permalink) | |
Junior Member Join Date: Mar 2010
Member: 1269716 Status: Offline Thanks Meter: 4 | Quote:
Changes log in chimera web HTC: New models added: Desire 820 (a51dtul) : Direct Unlock, IMEI Repair, Change CID, Unlock BootLoader Desire 626s (htc_a32eul) : Direct Unlock, Remove FRP, IMEI Repair, S-ON/S-OFF, Change CID, Unlock BootLoader M9 AT&T (htc_himaulatt) : Direct Unlock, Remove FRP, IMEI Repair, S-ON/S-OFF, Change CID, Unlock BootLoader | |
The Following User Says Thank You to kevinoddis For This Useful Post: |
01-19-2017, 09:07 | #5 (permalink) |
Product Supporter Join Date: Dec 2004 Location: Furious Team ... GPGIndustries Age: 45
Member: 95960 Status: Offline Sonork: 100.1574721 Thanks Meter: 14,045 | is your HTC is locked to MetroPCS ?? |
The Following User Says Thank You to Fast Unlocker For This Useful Post: |
01-19-2017, 12:53 | #6 (permalink) |
Member: 1269716 Status: Offline Thanks Meter: 4 | I have Two metropcs phone, converted to cricket, unlock done chimera, but just one with signal, the other ask for code unlock |
01-20-2017, 01:24 | #7 (permalink) |
Freak Poster Join Date: Jun 2012 Location: Jamaica Age: 39
Member: 1769612 Status: Offline Sonork: 100.1626332 Thanks Meter: 24 | I'm having the same problem with two metropcs versions and im on the latest version of chimeratool. |
The Following User Says Thank You to ketoevans For This Useful Post: |
01-25-2017, 15:32 | #9 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,741 | Dear Users, at the moment we have not solution for the metro pcs models. Really sorry for the inconveniences and thank you for the patience. Best regards Nicole |
01-26-2017, 21:29 | #10 (permalink) |
Junior Member Join Date: Aug 2006 Location: Colombia
Member: 336143 Status: Offline Thanks Meter: 1 | i have a htc desire 626s from claro colombia model opm9110 when i connect to the pc chimera tool says only development support, no other function, please what im doing wrong or this model is not supported? |
01-27-2017, 19:05 | #12 (permalink) |
Member: 336143 Status: Offline Thanks Meter: 1 | chimera tool public beta works perfect, i connect the htc to the pc inmediately and all options appear, the process takes 5 minutes, thanks chimera team, good work |
The Following User Says Thank You to Raven21 For This Useful Post: |
02-03-2017, 19:32 | #13 (permalink) |
Junior Member Join Date: Oct 2014 Location: iquique
Member: 2278760 Status: Offline Thanks Meter: 3 | Hi Team Chimera, please help NO REPAIR IMEI- NO S-OFF Waiting for ADB device Initializing recovery mode Recovery mode detected, preparing phone, do not touch the phone. Gathering phone informations Communicating with Chimera server Preparing the phone for the procedure Calculating encrypted datas Rebooting in recovery mode 1.) Please switch to DOWNLOAD mode by pressing the VOLUME UP and POWER buttons until the screen will be blank 2.) Then quickly release them and press VOLUME DOWN until the DOWNLOAD menu comes on. 3.) Please select BOOTLOADER option, then boot into RECOVERY mode. Cleaning up Checking Current security flag: 3 Failed to set security flag! Finished at local time: [02.03.17 19:25:33] WorkID: 17617590 |
02-06-2017, 16:04 | #15 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,741 | reply Dear Sir, please install the necessary drivers from the chimeratool software (drivers menu) and try again the process. Best regards Nicole Quote:
