10-09-2019, 08:12 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: usa
Member: 2372074 Status: Offline Sonork: 100.1663814 Thanks Meter: 167 | g935f u5 8.0 imei repair done by chimera Printing phone history Repair IMEI 2019-mm-08 4:59:31 PM Repair IMEI 2019-mm-08 4:53:12 PM Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G935F Sales Code: CHV Country Code: Chile Timezone: Asia/Karachi Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Thu May 23 22:18:54 KST 2019 PDA Version: G935FXXS5ESEF [may 2019, revF] Phone Version: G935FXXS5ESED [may 2019, revD] CSC Version: G935FUWC5ESEA [may 2019, revA] Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: R58HA157PRM Imei: 00000000000000 Battery Status: 3.83V (51%) Network Type: GSM SIM Status: READY,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-05-01 Data Encryption State: unencrypted Repair imei... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Repaired IMEI: 35XXXXXXXXXXXX Repaired IMEI2: 35XXXXXXXXXXX If necessary, use the patch cert procedure. Succeeded. Successfully finished. Finished at local time: [10.08.19 22:03:39] Chimera Mobile Phone Utility version: 22.59.0754 @ 2019-10-08 Printing phone history Repair IMEI 2019-mm-08 5:02:16 PM Repair IMEI 2019-mm-08 4:59:31 PM Repair IMEI 2019-mm-08 4:53:12 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G935F Sales Code: CHV Country Code: Chile Timezone: Asia/Karachi Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Thu May 23 22:18:54 KST 2019 PDA Version: G935FXXS5ESEF [may 2019, revF] Phone Version: G935FXXS5ESED [may 2019, revD] CSC Version: G935FUWC5ESEA [may 2019, revA] Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: R58HA157PRM Imei: 35XXXXXXXXXXX Battery Status: 3.79V (51%) Network Type: GSM SIM Status: READY,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-05-01 Data Encryption State: unencrypted Preparing... Checking current patchcert. Checking modem. Checking root. The phone is rooted by: 19.4-c1602d25:MAGISKSU Checking boot image. Be patient! Do NOT disconnect the phone! The knox is still valid. Because of the boot patch the warranty will void. Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... The operation is in progress. Be patient! Do NOT disconnect the phone! After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [10.08.19 22:08:54] file link herehttps://zee.gl/HoqxIdo |
The Following 2 Users Say Thank You to ahmerrafiq30 For This Useful Post: |
10-10-2019, 08:16 | #2 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: Pretoria South Africa Age: 45
Member: 132635 Status: Offline Thanks Meter: 360 | Quote:
Can u give us other link? | |
10-10-2019, 14:42 | #4 (permalink) |
Member: 2372074 Status: Offline Sonork: 100.1663814 Thanks Meter: 167 | |
