05-28-2020, 14:43 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: turkey
Member: 706822 Status: Offline Thanks Meter: 647 | A505F U4 Q10 ROOT-REPAİR-PATCH done mathew_di ;) Printing phone history SW Change 28.05.2020 09:40:29 Patch Certificate 28.05.2020 09:38:09 Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A505F Sales Code: TUR Country Code: TURKEY Timezone: Europe/Istanbul Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Thu Jan 2 12:50:30 KST 2020 PDA Version: A505FDDS4ATA1 [january 2020, rev1] Phone Version: A505FXXS4ATA1 [january 2020, rev1] CSC Version: A505FOJM4ATA1 [january 2020, rev1] Product Code: TUR HIDSw Version: A505FDDS4ATA1/A505FOJM4ATA1/A505FXXS4ATA1/A505FDDS4ATA1 Board Platform: EXYNOS5 Modem Platform: SHANNON337 Serial Number: RZ8MA1RZBXA Imei: 359830100195152 Unique Number: CE091939D958110C057E Connections: AT,MTP Battery Status: 4.13V (82%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-01-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 359830100195152 Repaired imei: 353183067 Successfully finished. Finished at local time: [05.28.20 13:34:00] WorkID: 96370554 Chimera Mobile Phone Utility version: 24.85.1531 @ 2020-05-28 Printing phone history Patch Certificate 28.05.2020 13:04:12 SW Change 28.05.2020 12:48:40 SW Change 28.05.2020 12:14:59 Patch Certificate 28.05.2020 11:35:29 SW Change 28.05.2020 11:34:18 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A505F Sales Code: INS Country Code: India Timezone: Europe/Istanbul Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Fri Mar 6 17:36:42 KST 2020 PDA Version: A505FDDU4BTC4 [march 2020, rev4] Phone Version: A505FXXU4BTC2 [march 2020, rev2] CSC Version: A505FODM4BTC2 [march 2020, rev2] Product Code: INS HIDSw Version: A505FDDU4BTC4/A505FODM4BTC2/A505FXXU4BTC2/A505FDDU4BTC4 Board Platform: UNIVERSAL9610 Modem Platform: SHANNON337 Serial Number: RZ8MA1RZBXA Imei: 353183067 Unique Number: CE091939D958110C057E Connections: AT,MTP Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-02-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [05.28.20 16:08:49] WorkID: 96385917 |
The Following 3 Users Say Thank You to mathew_di For This Useful Post: |
09-06-2020, 19:21 | #2 (permalink) |
Junior Member Join Date: Aug 2017 Location: Turkey
Member: 2750746 Status: Offline Thanks Meter: 0 | hey. thank you for share , but im trying and failing everytime, can you teach shortly what to do? cause i rooted the device with magisk also tried eftsu . roots succesfully but when im trying to patch it fails |
