11-09-2018, 12:32 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Samsung Galaxy A5 2016 SM-A510F Read Codes Repair IMEI SW Change Unlock Device Info Firmware Compatibility Info Patch Certificate Read Cert Reboot Repair EFS Reset FRP Lock Reset Screen Lock Restore / Store backup Root / Unroot Write Cert Paid features Read Codes Online 25 CRD / phone When the Imei is in 35000000 that means that the EFS folder is corrupted and the security of the phone is damaged. If either SW version is unknown, or HW Chip is unknown, or HW Modem is unknown - most likely phone's firmware firmware or EFS is damaged, or you have written unsuitable firmware. Also, this can be HW problem. You should re-flash the device with different firmware one by one and check, if modem is correct (not Unknown). If after writing of all firmwares, which you have, problem remains the same - most likely, this is HW problem (problem with eMMC flash chip). |
11-13-2018, 20:05 | #5 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, just reflash device with combination firmware check status on recovery mode... perform full wipe and check status again... post pictures... Best Regards Shensohau |
The Following User Says Thank You to Shensohau For This Useful Post: |
