05-19-2020, 19:12 | #1 (permalink) |
Freak Poster Join Date: Oct 2014 Location: efs Age: 33
Member: 2279944 Status: Offline Sonork: not avaliable Thanks Meter: 167 | A515f patch cert fail..as like N770f Printing phone history Repair IMEI 19.05.2020 17:57:34 Repair IMEI 16.05.2020 21:16:00 Repair IMEI 16.05.2020 20:25:40 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A515F Sales Code: TUR Country Code: TURKEY Timezone: Europe/Istanbul Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Thu Feb 6 20:31:42 KST 2020 PDA Version: A515FXXU2ATB1 [february 2020, rev1] Phone Version: A515FXXU2ATA8 [january 2020, rev8] CSC Version: A515FOJM2ATB2 [february 2020, rev2] Product Code: TUR HIDSw Version: A515FXXU2ATB1/A515FOJM2ATB2/A515FXXU2ATA8/A515FXXU2ATB1 Board Platform: UNIVERSAL9611 Modem Platform: SHANNON337 Serial Number: RZ8MC18B4DL Imei: 352xxxxxxxxxxxxxxxxx Unique Number: CE11193B70EFECAD3F7E Connections: AT,MTP Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-02-01 Preparing... Checking root access. The phone is rooted by: 20.5:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. Unable to patch certificate. Finished at local time: [05.19.20 21:07:31] WorkID: 95679330 phone rootred as you can se,but while tool asks for root at second time,device restard and prosses failed..pleasw solve this tool only works with eft patched boot images,we want support for magisk patched boot imgs supports |
05-24-2020, 15:30 | #4 (permalink) |
Freak Poster Join Date: Jun 2010 Location: South Azerbaycan Age: 40
Member: 1333047 Status: Offline Sonork: 100.1618775 Thanks Meter: 278 | I found a different version! 💪 Code: Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A515F Sales Code: XSG Country Code: UAE Timezone: Asia/Tehran Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Tue Apr 21 23:03:39 KST 2020 PDA Version: A515FXXU3BTD4 [april 2020, rev4] Phone Version: A515FXXU3ATC1 [march 2020, rev1] CSC Version: A515FOJM3BTD4 [april 2020, rev4] Product Code: XSG HIDSw Version: A515FXXU3BTD4/A515FOJM3BTD4/A515FXXU3ATC1/A515FXXU3BTD4 Board Platform: UNIVERSAL9611 Modem Platform: SHANNON337 Serial Number: RZ8N10MBRZR Imei: 351692040674284 Unique Number: CE12193C5B1F11263F7E Connections: AT,MTP Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-04-01 Preparing... Checking root access. The phone is rooted by: cd6eca1d:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [05.24.20 07:29:05] WorkID: 96102113 |
The Following User Says Thank You to aydin.gsm1 For This Useful Post: |
05-25-2020, 01:42 | #5 (permalink) |
Member: 2279944 Status: Offline Sonork: not avaliable Thanks Meter: 167 | this a515f boot img patched by the developer of magisk... and he sent it to me,this version will be publish about 2 weeks later,now on development |
05-25-2020, 01:48 | #6 (permalink) |
Member: 2279944 Status: Offline Sonork: not avaliable Thanks Meter: 167 | and u3 modems not supported by chimera, how you patch cert,have you any proof and can you take a screenshot,because i dont want to upgrade my device to an unsupported security build |
05-28-2020, 00:18 | #9 (permalink) | |
Member: 2279944 Status: Offline Sonork: not avaliable Thanks Meter: 167 | Quote:
can u share your root file?? | |
07-31-2020, 08:02 | #13 (permalink) |
Freak Poster Join Date: Jun 2013 Location: south Africa
Member: 1960717 Status: Offline Sonork: 100.1638403 Thanks Meter: 34 | Timezone: Africa/Johannesburg Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Wed May 20 19:06:55 KST 2020 PDA Version: N770FXXU3BTE5 [may 2020, rev5] Phone Version: N770FXXU3BTE4 [may 2020, rev4] CSC Version: N770FOJM3BTE4 [may 2020, rev4] Product Code: XFA HIDSw Version: N770FXXU3BTE5/N770FOJM3BTE4/N770FXXU3BTE4/N770FXXU3BTE5 Board Platform: UNIVERSAL9810 Modem Platform: SHANNON360 Serial Number: RF8N1211FFP Imei: 354757866444760 Unique Number: CE12193CB230653A3F7E Connections: AT,MTP Network Type: GSM SIM Status: LOADED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-05-01 Preparing... Checking root access. The phone is rooted by: cd6eca1d:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Unsupported modem. Install another firmware and try again. |
07-31-2020, 14:53 | #14 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,709 | reply Dear User, Please provide us the WORK ID from the Job so we can check the problem properly! Best regards Sab Quote:
