a600g 9.0 U5 patch cert succesfully. Chimera Mobile Phone Utility version: 21.68.1040 @ 2019-07-12 Printing phone history Repair IMEI 12.07.2019 11:44:55 Read Cert 12.07.2019 11:15:53 Knoxguard Unlock 12.07.2019 10:53:20 Knoxguard Unlock 12.07.2019 10:49:24 Rmm Unlock 12.07.2019 10:47:34 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A600G Sales Code: THL Country Code: THAILAND Timezone: Europe/Istanbul Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue May 28 20:28:53 KST 2019 PDA Version: A600GDXU5BSE3 [may 2019, rev3] Phone Version: A600GDXU5BSE3 [may 2019, rev3] CSC Version: A600GOLM5BSE3 [may 2019, rev3] Product Code: THL HIDSw Version: A600GDXU5BSE3/A600GOLM5BSE3/A600GDXU5BSE3/A600GDXU5BSE3 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: RF8K60B1LJB Imei: 35... Unique Number: CBJ00876AEE9F35 Connections: AT,MTP Battery Status: 4.20V (90%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-04-01 Data Encryption State: unencrypted Preparing... Checking current patchcert. Checking modem. Checking root. The phone is rooted by: 19.2:MAGISKSU Checking boot image. Be patient! Do NOT disconnect the phone! The knox is still valid. Because of the boot patch the warranty will void. Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... The operation is in progress. Be patient! Do NOT disconnect the phone! After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [07.12.19 14:52:59] WorkID: 65961383 but the knoxguard is not working, the authorities will take care of it. :) good luck |
reply Hi, thank you for the feedback KG unlock will be checked shortly. Best regards Nicole Quote:
problem unlock rmm Code: Chimera Mobile Phone Utility version: 21.76.1421 @ ۲۰۱۹-۰۷-۲۴ |
in android 9 no need any option for knox guard only must connect to wifi and wait 1 minute and check again developer options and see oem Quote:
