12-30-2018, 12:47 | #16 (permalink) |
Freak Poster Join Date: Oct 2017
Member: 2765995 Status: Offline Thanks Meter: 8 | me personally i paid to get mine done as lack of support on this model meant i had to turn to someone else so would be nice to post a walkthrough or pointers on uk models if the poster had posted the password for the file , then i would of tested this method when i had the handset , but i dont have it now |
12-30-2018, 12:49 | #17 (permalink) |
Member: 2765995 Status: Offline Thanks Meter: 8 | i unfortunate paid someone remote to do mine , as the poster on this file never posted the password so couldnt test but if there is a file for uk model , and a TUT or pointers would be fantastic and i can only say sorry for negativity on my approach |
12-30-2018, 14:19 | #18 (permalink) |
Freak Poster Join Date: Jan 2012 Location: Kilis
Member: 1715473 Status: Offline Thanks Meter: 105 | I share photos of possible problems. No Oem Lock. Screen rotation does not work. Ota is not getting the update. The software of each model is not compatible with each other and sometimes fails when loading. The model I shared is c636. Accidentally installed C432 file. The version falls but the correct file is the correct model number and the correct country distribution. for the sake of your sake.load the file you want. but share your thoughts and questions without breaking anybody. |
01-03-2019, 14:58 | #22 (permalink) | |
Freak Poster Join Date: Jun 2009
Member: 1059059 Status: Offline Thanks Meter: 18 | hi bro password please Quote:
01-03-2019, 18:10 | #24 (permalink) | |
Junior Member Join Date: Sep 2017
Member: 2761691 Status: Offline Thanks Meter: 6 | Quote:
01-04-2019, 10:13 | #25 (permalink) |
Member: 2761691 Status: Offline Thanks Meter: 6 | no password, but I find the way how to do this 1. You need to make downgrade site androidhost .ru, then 'SEARCH FILES', look C*** for your phone (for mine, I check it before in octoplus frp tool 'read info'), I use software Huawei P20 Lite Anne-L01 ANE-L01 + ANE-L21 8.0.0.125(C432) 2. Create a folder into a SD card, rename it to DLOAD, put file inside (update + one folder L01 or L21), flash device as normal (3 buttons), after finish need FORMAT device!! (power + vol UP ), follow steps, after format device will start normally, now you can perform FRP unlock or REPAIR 3. Install new software, I use Huawei P20 Lite ANE-LX1 ANE-L01 8.0.0.149(C432) Then FORMAT device!, finished, now all work, see updates |
The Following 3 Users Say Thank You to yura_if For This Useful Post: |
01-04-2019, 10:35 | #26 (permalink) | |
Member: 1715473 Status: Offline Thanks Meter: 105 | Quote:
but the other friend is uploading files according to his head without looking at the region number. but it does not know that the device will not receive an update and the screen will not return. or the device will be brick. Your transaction is the most accurate operation. | |
The Following User Says Thank You to nbrios For This Useful Post: |
01-08-2019, 22:33 | #27 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Portugal
Member: 478535 Status: Offline Thanks Meter: 433 | Quote:
User Ersa never show in any way the p20 lite version. The log only show the work id. Shensohau offered user Ersa, without any other question, the downgrade file. Chimera is a server based solution. Any question, just ask. Shensohau help a big lot! | |
01-22-2019, 20:44 | #28 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: Now on earth Age: 48
Member: 75290 Status: Offline Thanks Meter: 57 | Quote:
What is the pass to file HALABTECH_TEAM.7z ??? another firmware? still try... this is not so easy | |
01-22-2019, 21:05 | #29 (permalink) | ||
And so we can help you, we need to know the correct version of firmware on phone. If possible, put phone in fastboot mode and do a fastboot getvar all. Post here the resulting log with serial/imei/board sn redacted! | ||
