11-21-2018, 14:26 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Now on earth Age: 48
Member: 75290 Status: Offline Thanks Meter: 57 | ANE-LX1 IMEI Repair problem P20 Lite Searching for manufacture port... Testing connection... Checking IMEI(s)... Authenticating... This may take a while. Be patient! Do NOT disconnect the phone! The device sent an invalid challenge. Retry 2/5 The device sent an invalid challenge. Retry 3/5 The device sent an invalid challenge. Retry 4/5 The device sent an invalid challenge. Retry 5/5 The device sent an invalid challenge. Authentication with the device failed. Finished at local time: [11.21.18 14:15:27] WorkID: 47930097 |
11-21-2018, 14:52 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,747 | reply Hi, the problem comes from the new Huawei Key, firmware, the chimera tool is not supporting that version right now, but we are working on it already, hopefully we can release it very soon, of course all the users will be informed. Best regards: Nicole Quote:
The Following 4 Users Say Thank You to Chimera Tool For This Useful Post: |
11-21-2018, 14:54 | #3 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
This model sometimes gives problems with the drivers You could do * # * # 2846579 # * # * and enable manufacture mode until you take all the drivers. If the problem persists, maybe it's because you have the latest version and a very new security. | |
12-26-2018, 17:44 | #5 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | ANE-LX1 Huawei ANE-LX1 8.0 Repair imei And Reset Frp FILE How to USE it: Create a folder into a SD card, rename it to DLOAD, put file inside, flash device as normal, after finish, device will alsk you for FORMAT, follow steps, after format device will start normally after a 12-15 minutes, now you can perform FRP or REPAIR with Chimera.... |
The Following 6 Users Say Thank You to Shensohau For This Useful Post: |
12-28-2018, 22:04 | #7 (permalink) | |
Freak Poster Join Date: Oct 2017
Member: 2765995 Status: Offline Thanks Meter: 8 | Quote:
can we have password plz , | |
12-29-2018, 04:43 | #8 (permalink) | |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | Quote:
12-29-2018, 16:46 | #9 (permalink) | |
Freak Poster Join Date: Jan 2012 Location: Kilis
Member: 1715473 Status: Offline Thanks Meter: 105 | Quote:
unconscious software gives the screen rotation error. Let's not use the files unconscious. | |
12-30-2018, 10:08 | #11 (permalink) |
Member: 1715473 Status: Offline Thanks Meter: 105 | You don't know the job, then you shut up. P20 lite is running downgrade. but each region distribution is different. And you say cut me out? In the case of incompatible softwares, screen rotation and OEM lock are not active. Don't cry for help here tomorrow for that. Now you can play with your lying toys. |
12-30-2018, 10:30 | #12 (permalink) |
Member: 2765995 Status: Offline Thanks Meter: 8 | lmao , then pipe down and ask what region , this does not give you the right to tell someone not to post something ask them to clarify , dont you demand they stop posting who made you saviour , prat |
12-30-2018, 10:34 | #13 (permalink) | |
and if you knew the process and correct files , you would help the thread not sit there and watch with a smirk telling ppl this is not correct as you are clearly a master at this process ............ NOT | |
12-30-2018, 11:00 | #14 (permalink) |
Member: 1715473 Status: Offline Thanks Meter: 105 | I'm not cunning. I have helped many people in this forum. If you follow my posts, you can see how I've given my narration and support. Files are available everywhere. but there are also distortions either during installation or after loading. There will be problems that will occur later when the knowledgeable person who knows this distributes it without looking directly at the distribution number. Such a mistake would also know the manufacturer support of chimera or other boxes. and leaves the responsibility to you. You say that someone who is competent in this business is directing the end user, but I'm telling you the truth and why you shut up ? If someone says something, listen first and then react. This person is telling you the truths and risks. Don't make a fanboy. |
12-30-2018, 11:32 | #15 (permalink) | |
Even file publisher didn’t say anything tested or not , it’s risky to try but you can try if you want | |
