11-23-2017, 11:42 | #1 (permalink) |
Insane Poster Join Date: Jul 2010 Location: Bangladesh
Member: 1341039 Status: Offline Thanks Meter: 40 | HTC One A9 - IMEI Repair with ChimeraTool HTC One A9 - IMEI Repair with ChimeraTool Chimera Mobile Phone Utility version: 15.72.1314 @ 2017-11-23 Printing phone history Repair IMEI 11/23/2017 10:23:58 AM Repair IMEI 11/23/2017 9:51:37 AM [IMEI repair started] Rebooting in fastboot mode Phone detected Current security state: 3 Checking current security flag Downloading recovery image from server. Please hold on, it can take some time. Recovery image has been downloaded. Switching to fastboot mode Phone detected Checking bootloader state... Phone detected Using new method Rebooting in bootloader mode Phone detected Bootloader is locked Rebooting in download mode Phone detected Bootloader unlock is required, asking server for access Gathering bootloader information  All user data will be lost and the phone will reset to factory default! You will see the disclaimer on the screen now. Please read this carefully as this action may void your warranty. Please select 'Yes' to continue the procedure. Use the volume buttons to highlight your choice and the Power button to make your selection (If you select Yes, your phone will be reset to its factory default settings, and your bootloader will be unlocked.If you select No, your phone will reboot and no modifications will have been made.) Waiting for bootloader unlock to finish Fastboot detached. 1.) When the HTC logo appears on the screen, 1.) Please switch to DOWNLOAD mode by pressing the VOLUME UP and POWER buttons until the screen will be blank 2.) Then quickly release them and press VOLUME DOWN and POWER until the DOWNLOAD menu comes on. Phone detected Installing recovery image Installing was successful 1.) Please select REBOOT TO BOOTLOADER option from Download mode menu 2.) Select BOOT TO RECOVERY MODE option from the BOOTLOADER menu Waiting for ADB device Initializing recovery mode Recovery mode detected, preparing phone, do not touch the phone. Waiting for the phone... Gathering phone information Communicating with Chimera server Preparing the phone for the procedure Calculating encrypted data Rebooting in recovery mode Cleaning up Checking Current security flag: 0 Information Your phone may asks for decryption password after it boots. Please type a single zero digit, then press the enter button. After that the phone will ask you for FACTORY RESET. Push the reset button, then please go to the Wipe menu in the TWRP recovery and pull the sliding bar to reset. After that you can boot into system mode and use the phone as usual. Restarting in fastboot mode Phone detected Writing IMEI(s) IMEI 1 to write: 356784745745470 Checking current security flag Writing security flag Phone detected Security flag has been written: S-ON Finished successfully Finished at local time: [11.23.17 16:34:02] WorkID: 29585090 JONONItelecom™ http://forum.gsmhosting.com/vbb/member.php?u=1076772 |
The Following 5 Users Say Thank You to sadekul_esdo For This Useful Post: |
