03-21-2018, 16:47 | #2 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
so only original phone cert will work other phone from same model cert you get emergency call only Your device's EFS damaged ???? That is why the process can not be done. When the previously used tool created backup from the device it is worth to try to repair the EFS with it. At the moment you can not repair your device with other solution. Root your phone and upload the operation made with chimera in this post. Thank you! Samsung Galaxy J5 Prime SM-G570F SW Change Unlock Device Info Firmware Compatibility Info Read Cert Read / Write certificate Reboot Repair Device Root Key Reset FRP Lock Restore / Store backup Root / Unroot Set SIM Count Write Cert Paid features Read Codes Online 59 CRD / phone | |
The Following User Says Thank You to gcceleghg For This Useful Post: |
