03-08-2018, 18:25 | #1 (permalink) |
No Life Poster Join Date: Feb 2015 Location: Jamaican
Member: 2339843 Status: Offline Thanks Meter: 1,450 | Chimera hits deadly!!!!have a look Printing phone history Read Codes 31/08/2017 04:18:41 PM Root/Unroot 31/08/2017 04:18:12 PM Unlock 31/08/2017 04:14:28 PM [Read codes started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-T377T Sales Code: TMB Country Code: USA Timezone: America/New_York Android Version: 6.0.1 [MMB29K] Build Date: Thu Dec 8 21:13:36 KST 2016 PDA Version: T377TUVS1APL1 [december 2016, rev1] Phone Version: T377TUVS1APL1 [december 2016, rev1] CSC Version: T377TTMB1APL1 [december 2016, rev1] Product Code: XXXXXXXXXXXTMB HIDSw Version: T377TUVS1APL1/T377TTMB1APL1/T377TUVS1APL1/T377TUVS1APL1 Board Platform: EXYNOS3 Modem Platform: SHANNON308 Serial Number: R52J10KCFBM Imei: 356425072668808 Unique Number: CAJ03C4085057C3 Connections: AT,MTP Battery Status: 4.03V (74%) Network Type: GSM SIM Status: NETWORK_LOCKED Knox Version: v30 Warranty Bit: 0 Security Patch: 2016-03-01 Data Encryption State: unencrypted Reading Codes... Please unlock screen lock if closed! Trying on SAMSUNG Mobile USB Modem (COM100) Processing. Be patient! Do NOT disconnect the phone! Calculating. MasterLock: 17352573 NetworkLock: 41636073 SubsetLock: 00000000 SpLock: 00000000 CpLock: 00000000 SimLock: 00000000 Finished successfully. Finished at local time: [08.31.17 11:25:57] WorkID: 25894955 Chimera Mobile Phone Utility version: 14.91.1355 @ 2017-08-31 [Direct unlock started] Downloading recovery image from server. Please hold on, it can take some time. Recovery image has been downloaded. Switching to fastboot mode Phone detected Checking bootloader state... Phone detected Using new method Rebooting in bootloader mode Phone detected Bootloader is locked Rebooting in download mode Phone detected Bootloader unlock is required, asking server for access Gathering bootloader information ? All user data will be lost and the phone will reset to factory default! You will see the disclaimer on the screen now. Please read this carefully as this action may void your warranty. Please select 'Yes' to continue the procedure. Use the volume buttons to highlight your choice and the Power button to make your selection (If you select Yes, your phone will be reset to its factory default settings, and your bootloader will be unlocked.If you select No, your phone will reboot and no modifications will have been made.) Waiting for bootloader unlock to finish Fastboot detached. 1.) When the HTC logo appears on the screen, 1.) Please switch to DOWNLOAD mode by pressing the VOLUME UP and POWER buttons until the screen will be blank 2.) Then quickly release them and press VOLUME DOWN and POWER until the DOWNLOAD menu comes on. Phone detected Installing recovery image Installing was successful 1.) Please select REBOOT TO BOOTLOADER option from Download mode menu 2.) Select BOOT TO RECOVERY MODE option from the BOOTLOADER menu Waiting for ADB device Initializing recovery mode Recovery mode detected, preparing phone, do not touch the phone. Preparing the phone for the procedure Calculating simlock Rebooting in recovery mode Cleaning up Information Your phone may asks for decryption password after it boots. Please type a single zero digit, then press the enter button. After that the phone will ask you for FACTORY RESET. Push the reset button, then please go to the Wipe menu in the TWRP recovery and pull the sliding bar to reset. After that you can boot into system mode and use the phone as usual. Finished successfully Finished at local time: [08.31.17 14:51:21] WorkID: 25906074 Chimera Mobile Phone Utility version: 16.39.1009 @ 2018-01-27 Printing phone history Unlock 28/01/2018 12:26:38 AM Unlock 28/01/2018 12:15:07 AM [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N910A Sales Code: ATT Country Code: USA Timezone: America/New_York Android Version: 6.0.1 [MMB29M] Build Date: Thu Aug 10 18:54:59 KST 2017 PDA Version: N910AUCS2EQH1 [august 2017, rev1] Phone Version: N910AUCU2DOI2 [september 2015, rev2] CSC Version: N910AATT2EQH1 [august 2017, rev1] Board Platform: APQ8084 Modem Platform: MDM9225M Serial Number: R38FB0HA5TY Imei: 354483062373196 Battery Status: 3.93V (84%) Network Type: GSM SIM Status: ABSENT Knox Version: v30 Warranty Bit: 0 Security Patch: 2017-08-01 Data Encryption State: unencrypted Checking root state... Not rooted. There is no backup, because there is no root access. Unlocking... Trying on SAMSUNG Mobile USB Serial Port (COM97) Protocol is not supported. Trying on SAMSUNG Mobile USB Serial Port (COM121) Unlocked. Finished successfully. Finished at local time: [01.27.18 19:30:44] WorkID: 32610231 Chimera Mobile Phone Utility version: 16.44.1316 @ 2018-01-31 [Read codes started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G610F Sales Code: XME Country Code: MALAYSIA Timezone: Europe/London Android Version: 7.0 [NRD90M] Build Date: Fri Nov 10 12:03:28 KST 2017 PDA Version: G610FDXU1BQK2 [november 2017, rev2] Phone Version: G610FDDU1BQJ4 [october 2017, rev4] CSC Version: G610FOLB1BQK2 [november 2017, rev2] Product Code: XME HIDSw Version: G610FDXU1BQK2/G610FOLB1BQK2/G610FDDU1BQJ4/G610FDXU1BQK2 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: R58JB4JG5DF Imei: 352810096461252 Unique Number: CBJ10A58AEA4974 Connections: AT,MTP Battery Status: 3.99V (69%) Network Type: GSM SIM Status: NETWORK_LOCKED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2017-08-01 Data Encryption State: encrypted Reading Codes... Searching serial port. Be patient! Do NOT disconnect the phone! Serial port found on COM50 Reading data. Be patient! Do NOT disconnect the phone! Master Lock: 69397253 Network Lock: 79318097 Subset Lock: 00000000 SP Lock: 00000000 CP Lock: 00000000 SIM Lock: 00000000 Finished successfully. Finished at local time: [01.31.18 11:48:01] WorkID: 32768406 Chimera Mobile Phone Utility version: 16.67.1014 @ 2018-02-28 [Read codes started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G920I Sales Code: JDI Country Code: JAMAICA Timezone: America/New_York Android Version: 7.0 [NRD90M] Build Date: Tue Jul 4 05:02:21 KST 2017 PDA Version: G920IDVU3FQG1 [july 2017, rev1] Phone Version: G920IDVU3FQF2 [june 2017, rev2] CSC Version: G920IJDI3FQG1 [july 2017, rev1] Product Code: JDI HIDSw Version: G920IDVU3FQG1/G920IJDI3FQG1/G920IDVU3FQF2/G920IDVU3FQG1 Board Platform: EXYNOS5 Modem Platform: SHANNON333 Serial Number: R58G50VETJT Imei: 357215067762776 Unique Number: 04157DF4A2BA7715 Connections: AT,MTP Battery Status: 3.96V (75%) Network Type: GSM SIM Status: READY Knox Version: v30 Warranty Bit: 0 Security Patch: 2017-07-01 Data Encryption State: unencrypted Reading Codes... Searching serial port. Be patient! Do NOT disconnect the phone! Serial port found on COM358 Reading data. Be patient! Do NOT disconnect the phone! Master Lock: 50273184 Network Lock: 19462702 Subset Lock: 00000000 SP Lock: 00000000 CP Lock: 00000000 SIM Lock: 00000000 Finished successfully. Finished at local time: [02.28.18 10:38:08] WorkID: 34078809 Chimera Mobile Phone Utility version: 16.67.1014 @ 2018-02-28 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SGH-M919 Sales Code: TMB Country Code: USA Timezone: America/New_York Android Version: 4.4.4 [KTU84P] Build Date: Wed Aug 27 21:41:58 KST 2014 PDA Version: M919UVUFNH7 [august 2014, rev7] Phone Version: M919UVUFNH7 [august 2014, rev7] CSC Version: M919TMBFNH7 [august 2014, rev7] Product Code: XXXXXXXXXXXTMB HIDSw Version: M919UVUFNH7/M919TMBFNH7/M919UVUFNH7/M919UVUFNH7 Board Platform: MSM8960 Modem Platform: MDM9215M Serial Number: RV8FA0GZ8HK Imei: 359086058091683 Unique Number: C16041B65A75781 Connections: AT,MTP Battery Status: 3.96V (62%) Network Type: GSM SIM Status: NETWORK_LOCKED Knox Version: v30 Warranty Bit: 0 Data Encryption State: unencrypted Checking root state... Not rooted. There is no backup, because there is no root access. Unlocking... Trying on SAMSUNG Mobile USB Serial Port (COM374) Protocol is not supported. Trying on SAMSUNG Mobile USB Serial Port (COM384) Unlocked. Finished successfully. Finished at local time: [02.28.18 16:42:22] WorkID: 34100592 Chimera Mobile Phone Utility version: 16.67.1014 @ 2018-02-28 Printing phone history Reset FRP/Reactivation Lock 23/02/2018 08:52:40 PM Reset FRP Lock 21/02/2018 06:53:58 PM Reset FRP Lock 21/02/2018 06:53:39 PM Reset FRP Lock 07/02/2018 12:19:58 AM Reset FRP Lock 25/01/2018 03:30:19 PM [Reset FRP/Reactivation lock started] Selected model: SM-T567V Checking firmware image... Present. Flashing firmware image... Flashing firmware image. Flashing firmware... Waiting for download mode. Connecting. Reading PIT from phone. Flashing image. Restarting phone. To complete FRP/Reactivation Reset goto "Backup and reset" and select "Factory data reset". Succeeded. Finished successfully. Finished at local time: [02.28.18 19:01:09] WorkID: 34106341 Chimera Mobile Phone Utility version: 16.67.1014 @ 2018-03-06 [Read codes started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G935F Sales Code: EVR Country Code: UK Timezone: Pacific/Midway Android Version: 7.0 [NRD90M] Build Date: Thu Mar 16 15:18:56 KST 2017 PDA Version: G935FXXU1DQCG [march 2017, revG] Phone Version: G935FXXU1DQCG [march 2017, revG] CSC Version: G935FEVR1DQC1 [march 2017, rev1] Product Code: EVR HIDSw Version: G935FXXU1DQCG/G935FEVR1DQC1/G935FXXU1DQCG/G935FXXU1DQCG Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: R58H74PMZTD Imei: 357330076023670 Unique Number: CE061606DA250F3D03 Connections: AT,MTP Battery Status: 3.73V (17%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2017-03-01 Data Encryption State: encrypted Reading Codes... Searching serial port. Be patient! Do NOT disconnect the phone! Serial port found on COM530 Reading data. Be patient! Do NOT disconnect the phone! Master Lock: 29608629 Network Lock: 84925757 Subset Lock: 00000000 SP Lock: 00000000 CP Lock: 00000000 SIM Lock: 00000000 Finished successfully. Finished at local time: [03.06.18 10:15:42] WorkID: 34361012 Chimera Mobile Phone Utility version: 16.67.1014 @ 2018-03-08 Printing phone history Read Codes 08/03/2018 03:51:42 PM [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G920T1 Sales Code: TMB Country Code: USA Timezone: America/Jamaica Android Version: 7.0 [NRD90M] Build Date: Wed Jan 10 17:32:29 KST 2018 PDA Version: G920T1UVS6FRA3 [january 2018, rev3] Phone Version: G920T1UVS6FRA3 [january 2018, rev3] CSC Version: G920T1TMB6FRA3 [january 2018, rev3] Product Code: TMB HIDSw Version: G920T1UVS6FRA3/G920T1TMB6FRA3/G920T1UVS6FRA3/G920T1UVS6FRA3 Board Platform: EXYNOS5 Modem Platform: SHANNON333 Serial Number: R58H13PHMGK Imei: 352322070752656 Unique Number: 1215FC4DC7620C05 Connections: AT,MTP Battery Status: 3.85V (62%) Network Type: GSM SIM Status: SIM_SERVICE_PROVIDER_LOCKED Knox Version: v30 Warranty Bit: 1 Security Patch: 2018-01-01 Data Encryption State: unsupported Unlocking... Reading and storing secure image. Be patient! Do NOT disconnect the phone! Preparing secure image. Be patient! Do NOT disconnect the phone! Trying on SAMSUNG Mobile USB Modem (COM544) Processing. Be patient! Do NOT disconnect the phone! Writing secure image. Unlocked. Finished successfully. Finished at local time: [03.08.18 11:07:35] WorkID: 34477464 [Read codes started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G920W8 Sales Code: FMC Country Code: Canada Timezone: America/St_Johns Android Version: 7.0 [NRD90M] Build Date: Fri Nov 3 18:46:29 KST 2017 PDA Version: G920W8VLS5DQK1 [november 2017, rev1] Phone Version: G920W8VLS5DQK1 [november 2017, rev1] CSC Version: G920W8OYA5DQK1 [november 2017, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON333 Serial Number: RF8G31ZXHMD Imei: 351559070188222 Battery Status: 4.05V (74%) Network Type: GSM SIM Status: ABSENT Knox Version: v30 Warranty Bit: 0 Security Patch: 2017-11-01 Data Encryption State: unencrypted Reading Codes... Searching serial port. Be patient! Do NOT disconnect the phone! Serial port found on COM553 Reading data. Be patient! Do NOT disconnect the phone! Master Lock: 95196282 Network Lock: 39736195 Subset Lock: 00000000 SP Lock: 00000000 CP Lock: 00000000 SIM Lock: 00000000 Finished successfully. Finished at local time: [03.08.18 12:12:15] WorkID: 34481984 |
The Following User Says Thank You to ziggywong0305 For This Useful Post: |
