01-28-2015, 12:50 | #611 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,741 | reply Dear ngoctoan242, Function for this model is still under developing. Top priority now is to solve Factory Unlock problem. Once it is done, we can continue adding new models and improving our functions so I kindly ask you please be patient. Best Regards, Chimera Team |
01-29-2015, 16:34 | #612 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2013 Location: XK Age: 26
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | HI THNX FOR GREAT UART ALGO I UNLOCKED POCKET 2 G110H Chimera Mobile Phone Utility version: 5.37.1707 @ 2015-01-29 [Unlock phone started.] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G110H Android Version: 4.4.2 Sales Code: SUW PDA Version: G110HXXU0ANJ3 Phone Version: G110HXXU0ANJ3 CSC Version: G110HSUW0ANK1 Product Code: SM-G110HZWASUW HIDSw Version: G110HXXU0ANJ3/G110HSUW0ANK1/G110HXXU0ANJ3/G110HXXU0ANJ3 Board Platform: SCX15 Serial Number: R21FC1427VZ Imei: 356886062458692 Unique Number: CN503A383C6B5B1 Connections: AT,MTP Battery Status: 3.96V (58%) Network Type: GSM Preparing... Reading images. Unlocking... 1. Disconnect micro USB cable 2. On dial window enter *#0808# (or *#9090# or *#7284#) and set DM+MODEM+ADB 3. Select OK on phone display 4. Connect micro UART cable 5. Click OK button Testing availability. Be patient! Do NOT disconnect the phone! Preparing MSL. Be patient! Do NOT disconnect the phone! Processing. Restart phone by using the phone's menu if it does not restart automatically! If needed use unlock code "12345678". Finished successfully. Finished at local time: [01.29.15 16:32:44] WorkID: 3899315 |
The Following User Says Thank You to BesfortShalaTec For This Useful Post: |
02-02-2015, 15:12 | #613 (permalink) |
Freak Poster Join Date: May 2011 Location: ettumanoor
Member: 1587303 Status: Offline Thanks Meter: 42 | I 9505 unlock done [Unlock phone started.] Checking serial port... Available. Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: GT-I9505 Android Version: 4.4.2 Sales Code: KSA PDA Version: I9505XXUGNH8 Phone Version: I9505XXUGNH8 CSC Version: I9505OJVFNG1 Baseband Version: M9615A-CEFWTAZM-4.0.17166 Board Platform: MSM8960 Serial Number: R21DA3NF45M Imei: 3585 FW Release Date: Jun 19 2014 FW Release Time: 03:00:00 FW Compilation Date: Aug 25 2014 FW Compilation Time: 16:37:12 Battery Status: 3.99V (71%) Network Type: GSM Checking serial port... Available. Unlocking... Unlock stage1 failed. Preparing modem image. Getting original modem... Reading original modem image. Be patient! Do NOT disconnect the phone! Storing original modem image to local disc. Getting new modem... Checking new modem image existence on local disc. Downloading new modem image. Be patient! Do NOT disconnect the phone! Checking image. Preparing new modem image. Waiting for battery remove/replace...
Phone removed. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Sending new modem... Writing new modem image. Be patient! Do NOT disconnect the phone! Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking modem version. Retrying unlock procedure. Checking serial port... Available. Unlocking... Unlocking successful. The phone will restart automatically. Be patient! Do NOT disconnect the phone! Waiting for restart... Waiting for restart. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Restoring original modem... Writing original modem image. Be patient! Do NOT disconnect the phone! Modem restored. Restarting phone. Finished successfully. Finished at local time: [02.02.15 19:38:43] WorkID: 3945338 |
The Following User Says Thank You to aravindanav For This Useful Post: |
02-02-2015, 20:39 | #614 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Madagascar
Member: 233142 Status: Offline Sonork: 100.1595099 Thanks Meter: 527 | GT S7390G unlock done Chimera Mobile Phone Utility version: 5.37.1707 @ 2015-02-02 [Unlock phone started.] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: GT-S7390G Android Version: 4.1.2 Sales Code: FTM PDA Version: S7390GXXUANC3 Phone Version: S7390GXXUANC1 CSC Version: S7390GFTMANC3 Board Platform: HAWAII Serial Number: R21F95JFQSZ Imei: 352905069007684 Battery Status: 4.10V (74%) Network Type: GSM Rooting by generic root method 2... Rooting in progress. Be patient! Do NOT disconnect the phone! Root method failed. Unlocking... Check the phone's display during the process! Unlocked. Finished successfully. Finished at local time: [02.02.15 22:28:36] WorkID: 3949960 |
The Following User Says Thank You to said4 For This Useful Post: |
02-02-2015, 22:49 | #615 (permalink) |
No Life Poster Join Date: Jan 2007
Member: 428656 Status: Offline Thanks Meter: 54 | I9305 failed kept failing on ZX via USB and Uart no such problems with Chimera Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: GT-I9305 Android Version: 4.3 Sales Code: EVR PDA Version: I9305XXUENH1 Phone Version: I9305XXUENG1 CSC Version: I9305EVRENH1 Baseband Version: M9615ACEHWMAZD179599 Board Platform: EXYNOS4 Serial Number: RF1D57LG4EY Imei: 356297051345603 FW Release Date: Dec 21 2012 FW Release Time: 03:00:00 FW Compilation Date: Jul 7 2014 FW Compilation Time: 23:17:27 Battery Status: 4.14V (90%) Network Type: GSM Checking serial port... Available. Unlocking... Unlock stage1 failed. Preparing modem image. Rooting by generic root method 2... Rooting in progress. Be patient! Do NOT disconnect the phone! Root method failed. Checking custom recovery root image... Downloading custom recovery root image. Be patient! Do NOT disconnect the phone! Checking image. Present. Rooting by custom recovery image based root method... Checking and untaring firmware... Checking MD5: 4F5D390C4E745814C2A782F60EC1B044. Untaring recovery.img. Untaring cache.img. Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. Reading PIT. Flashing recovery.img. Flashing cache.img. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Getting original modem... Reading original modem image. Be patient! Do NOT disconnect the phone! Storing original modem image to local disc. Getting new modem... Checking new modem image existence on local disc. Downloading new modem image. Be patient! Do NOT disconnect the phone! Checking image. Preparing new modem image. Waiting for battery remove/replace...  Disconnect usb cable. Remove battery and wait few seconds. Replace battery. Power on the phone. Reconnect usb cable. Phone removed. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Sending new modem... Writing new modem image. Be patient! Do NOT disconnect the phone! Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking modem version. Retrying unlock procedure. Checking serial port... Available. Unlocking... Unlocking successful. The phone will restart automatically. Be patient! Do NOT disconnect the phone! Waiting for restart... Waiting for restart. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Restoring original modem... Writing original modem image. Be patient! Do NOT disconnect the phone! Modem restored. Restarting phone. Finished successfully. Finished at local time: [02.02.15 22:46:46] WorkID: 3951648 |
The Following User Says Thank You to spitroastxxx For This Useful Post: |
