12-09-2019, 09:58 | #3811 (permalink) |
No Life Poster Join Date: Mar 2018 Location: Future.... ✌️
Member: 2825953 Status: Offline Thanks Meter: 246 | Printing phone history Knoxguard Unlock 12/8/2019 9:48:34 AM Rmm Unlock 12/8/2019 9:40:54 AM Knoxguard Unlock 12/8/2019 9:39:43 AM Repair IMEI 11/29/2019 1:33:01 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J720F Sales Code: THL Country Code: THAILAND Timezone: Africa/Johannesburg Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Fri Apr 5 16:48:18 KST 2019 PDA Version: J720FDDS4ASD1 [april 2019, rev1] Phone Version: J720FXXS4ASD3 [april 2019, rev3] CSC Version: J720FOLM4ASD1 [april 2019, rev1] Product Code: THL HIDSw Version: J720FDDS4ASD1/J720FOLM4ASD1/J720FXXS4ASD3/J720FDDS4ASD1 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: R28K50CPV0T Imei: 350098765432224 Unique Number: CBJ004BDE532535 Connections: AT,MTP Battery Status: 4.13V (81%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-04-01 Data Encryption State: unencrypted Preparing... Checking root access. The phone is rooted by: 21.0:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [12.08.19 11:54:53] |
12-09-2019, 10:00 | #3812 (permalink) |
Member: 2825953 Status: Offline Thanks Meter: 246 | Chimera Mobile Phone Utility version: 23.18.1359 @ 2019-12-07 Printing phone history Knoxguard Unlock 12/6/2019 12:36:48 PM Repair IMEI 12/6/2019 12:34:41 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A105F Sales Code: INS Country Code: India Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Jul 2 17:03:00 KST 2019 PDA Version: A105FDDU3ASG2 [july 2019, rev2] Phone Version: A105FDDU3ASG2 [july 2019, rev2] CSC Version: A105FODM3ASG2 [july 2019, rev2] Product Code: INS HIDSw Version: A105FDDU3ASG2/A105FODM3ASG2/A105FDDU3ASG2/A105FDDU3ASG2 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: RZ8M74A24JH Imei: 350098765435433 Unique Number: CBJ0070EF8F2866 Connections: AT,MTP Battery Status: 3.82V (38%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 19.3:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [12.07.19 14:30:12] |
12-09-2019, 10:11 | #3813 (permalink) |
Member: 2825953 Status: Offline Thanks Meter: 246 | Code: Chimera Mobile Phone Utility version: 23.10.1212 @ 2019-12-05 Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A520F Sales Code: XXV Country Code: VIETNAM Timezone: Africa/Johannesburg Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Tue Oct 1 18:39:43 KST 2019 PDA Version: A520FXXSBCSJ2 [october 2019, rev2] Phone Version: A520FXXUBCSI1 [september 2019, rev1] CSC Version: A520FOLBBCSI1 [september 2019, rev1] Product Code: XXV HIDSw Version: A520FXXSBCSJ2/A520FOLBBCSI1/A520FXXUBCSI1/A520FXXSBCSJ2 Board Platform: EXYNOS5 Modem Platform: SHANNON325 Serial Number: R58J65EQFAP Imei: 358651089802472 Unique Number: CBJ10A861F46944 Connections: AT,MTP Battery Status: 3.90V (42%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-10-01 Data Encryption State: encrypted Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 358651089802472 Repaired imei: 350098765444443 Successfully finished. Finished at local time: [12.05.19 16:54:30] Chimera Mobile Phone Utility version: 23.10.1212 @ 2019-12-05 Printing phone history Repair IMEI 12/5/2019 2:53:39 PM Patch certificate started Unable to detect IMEI number. Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A520F Sales Code: XXV Country Code: VIETNAM Timezone: Africa/Johannesburg Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Tue Oct 1 18:39:43 KST 2019 PDA Version: A520FXXSBCSJ2 [october 2019, rev2] Phone Version: A520FXXUBCSI1 [september 2019, rev1] CSC Version: A520FOLBBCSI1 [september 2019, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON325 Serial Number: R58J65EQFAP Imei: 350098765444443 Battery Status: 3.86V (43%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-10-01 Data Encryption State: unencrypted Preparing... Checking root access. The phone is rooted by: 18.1:MAGISKSU (topjohnwu) Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [12.05.19 17:07:48] |
12-10-2019, 14:06 | #3814 (permalink) |
No Life Poster Join Date: Jul 2006 Location: TÜRKİYE
Member: 311558 Status: Offline Thanks Meter: 476 | p8 lite 2017 repair log Chimera Mobile Phone Utility version: 23.18.1359 @ 2019-12-10 Printing phone history Repair IMEI 10.12.2019 12:19:57 Repair IMEI 10.12.2019 12:17:33 Repairing IMEI(s)... Factory reset notify window was accepted. Searching for manufacture port... Testing connection... Checking IMEI(s)... Old IMEI1:: 359776019074xx New IMEI1:: 35977601907cc Old IMEI2:: 359776019074v New IMEI2:: 3597760190740bbb Authenticating... This may take a while. Be patient! Do NOT disconnect the phone! Identifying... This may take a while. Be patient! Do NOT disconnect the phone! Repairing first IMEI... This may take a while. Be patient! Do NOT disconnect the phone! Repairing second IMEI... This may take a while. Be patient! Do NOT disconnect the phone! Resetting device to factory state... Finished at local time: [12.10.19 16:03:15] WorkID: 82352891 |
12-11-2019, 13:02 | #3816 (permalink) |
Member: 2825953 Status: Offline Thanks Meter: 246 | Code: Chimera Mobile Phone Utility version: 23.18.1359 @ 2019-12-11 Printing phone history Repair IMEI 12/11/2019 7:42:25 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A305F Sales Code: XME Country Code: MALAYSIA Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue May 28 10:46:14 KST 2019 PDA Version: A305FDDU2ASE5 [may 2019, rev5] Phone Version: A305FXXU2ASE5 [may 2019, rev5] CSC Version: A305FOLM2ASE5 [may 2019, rev5] Product Code: XME HIDSw Version: A305FDDU2ASE5/A305FOLM2ASE5/A305FXXU2ASE5/A305FDDU2ASE5 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: R58M51AP74Z Imei: 350098765433339 Unique Number: CCU00A39D490146 Connections: AT,MTP Battery Status: 3.86V (48%) Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 20.1:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [12.11.19 13:05:56] |
12-11-2019, 15:50 | #3817 (permalink) |
Member: 311558 Status: Offline Thanks Meter: 476 | g610f repair log Chimera Mobile Phone Utility version: 23.23.1154 @ 2019-12-11 Printing phone history Repair IMEI 11.12.2019 14:29:41 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G610F Sales Code: TUR Country Code: TURKEY Timezone: Europe/Istanbul Android Version: 6.0.1 [MMB29K] [SDK 23] Build Date: Wed Jul 19 14:49:08 KST 2017 PDA Version: G610FDDU1AQG2 [july 2017, rev2] Phone Version: G610FDDU1AQF4 [june 2017, rev4] CSC Version: G610FOJV1AQG2 [july 2017, rev2] Product Code: SM-G610FZDATUR HIDSw Version: G610FDDU1AQG2/G610FOJV1AQG2/G610FDDU1AQF4/G610FDDU1AQG2 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: R28J23GTDTB Imei: 359776019074071 Unique Number: CAJ03232C5A3614 Connections: AT,MTP Battery Status: 4.05V (72%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2017-07-01 Data Encryption State: encrypted Preparing... Checking current patchcert. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Previous patchcert successfully removed. Checking modem. Checking root. The phone is rooted by: 2.82:SUPERSU Checking boot image. Be patient! Do NOT disconnect the phone! Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... The operation is in progress. Be patient! Do NOT disconnect the phone! After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [12.11.19 17:45:29] WorkID: 82487166 |
12-12-2019, 14:19 | #3818 (permalink) |
No Life Poster Join Date: Jan 2006 Location: PORTUGAL
Member: 216446 Status: Offline Thanks Meter: 220 | SAMSUNG J330FN UNLOCK DONE SUCCESS.... Unlock phone started Unable to detect IMEI number. Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J330FN Sales Code: TCL Country Code: Portugal Timezone: Europe/Lisbon Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Thu May 30 18:57:54 KST 2019 PDA Version: J330FNXXS3BSF1 [june 2019, rev1] Phone Version: J330FNXXS3BSE1 [may 2019, rev1] CSC Version: J330FNVFG3BSC1 [march 2019, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON305 Serial Number: R58JB2WRZ4D Battery Status: 4.30V (100%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-06-01 Data Encryption State: encrypted Checking custom root image... Present. Rooting by custom image-based root method... Switching to download mode. Waiting for download mode. Connecting. SBL Info: Model: SM-J330FN, Region: EUR, Provider: OPEN, PDA: J330FNXXS3BSF1 Reading PIT from phone. Flashing boot.img Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Disabling Knox. Be patient! Do NOT disconnect the phone! Knox disabled. Unlocking... Reading and storing secure image. Be patient! Do NOT disconnect the phone! Checking secure image. Preparing. Please unlock screen if closed. Writing secure image. Unlocked. Successfully finished. Finished at local time: [12.12.19 13:16:56] WorkID: 82591565 |
12-13-2019, 11:03 | #3819 (permalink) |
Member: 311558 Status: Offline Thanks Meter: 476 | casper m1 imei repair log Chimera Mobile Phone Utility version: 23.24.1012 @ 2019-12-13 Repair IMEI Searching for manufacture port... Restarting the phone. Found preloader device: MediaTek PreLoader USB VCOM (Android) (COM10) Request sent Found factory port: MediaTek USB VCOM (Android) (COM46) Connected to the phone Writing new IMEI(s) Initializing... Writing new IMEI(s) Original IMEI1: 356049071301094 Original IMEI2: fffffffffffffff New IMEI1: 3597760190741xxx New IMEI2: 3597760190741xxx Done. Restarting the phone... Finished at local time: [12.13.19 12:59:48] WorkID: 82682319 |
12-15-2019, 13:03 | #3820 (permalink) |
Freak Poster Join Date: Jul 2017 Location: Globe
Member: 2742707 Status: Offline Thanks Meter: 138 | Code: Chimera Mobile Phone Utility version: 23.25.1456 @ 2019-12-15 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A205F Sales Code: XXV Country Code: VIETNAM Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Sun May 26 23:26:17 KST 2019 PDA Version: A205FXXU2ASE6 [may 2019, rev6] Phone Version: A205FDDU2ASE7 [may 2019, rev7] CSC Version: A205FOLM2ASE6 [may 2019, rev6] Product Code: XXV HIDSw Version: A205FXXU2ASE6/A205FOLM2ASE6/A205FDDU2ASE7/A205FXXU2ASE6 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: RZ8M615ZNPD Imei: 350098765445440 Unique Number: CBJ00BB9DC00756 Connections: AT,MTP Battery Status: 4.25V (100%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-04-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 19.3:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [12.15.19 14:01:19] |
12-16-2019, 15:41 | #3821 (permalink) |
Member: 311558 Status: Offline Thanks Meter: 476 | a705fn ds repair log Chimera Mobile Phone Utility version: 23.25.1456 @ 2019-12-16 Printing phone history Root/Unroot 16.12.2019 14:10:10 Repair IMEI 16.12.2019 14:06:39 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A750FN Sales Code: MAX Country Code: AUSTRIA Timezone: Europe/Istanbul Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Mon Aug 26 16:41:12 KST 2019 PDA Version: A750FNXXS2BSH7 [august 2019, rev7] Phone Version: A750FNXXS2BSH4 [august 2019, rev4] CSC Version: A750FNODX2BSH7 [august 2019, rev7] Product Code: MAX HIDSw Version: A750FNXXS2BSH7/A750FNODX2BSH7/A750FNXXS2BSH4/A750FNXXS2BSH7 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: RF8KB2BXPBJ Imei: 359776019074295 Unique Number: CCU00DF3FE80FB5 Connections: AT,MTP Battery Status: 3.95V (65%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-09-01 Data Encryption State: unencrypted Preparing... Checking root access. The phone is rooted by: 18.1:MAGISKSU (topjohnwu) Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [12.16.19 17:38:12] WorkID: 83006927 |
12-16-2019, 16:43 | #3822 (permalink) |
No Life Poster Join Date: Sep 2013 Location: KERALA, INDIA
Member: 2035802 Status: Offline Sonork: 100.1675827 Thanks Meter: 789 | Samsung M30 M307F country lock unlocked successfully Code: Chimera Mobile Phone Utility version: 23.25.1456 @ 2019-12-15 Printing phone history Read Codes Online 2019-mm-15 07:47:36 Read codes started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-M307F Sales Code: INS Country Code: India Timezone: Asia/Dubai Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Mon Oct 21 21:23:46 KST 2019 PDA Version: M307FXXU1ASJ2 [october 2019, rev2] Phone Version: M307FXXU1ASJ1 [october 2019, rev1] CSC Version: M307FODM1ASJ1 [october 2019, rev1] Product Code: INS HIDSw Version: M307FXXU1ASJ2/M307FODM1ASJ1/M307FXXU1ASJ1/M307FXXU1ASJ2 Board Platform: EXYNOS5 Modem Platform: SHANNON337 Serial Number: RZ8MB0RX0JH Imei: xxx Unique Number: CE10193A9107ED6F3F7E Connections: AT,MTP Battery Status: 4.17V (90%) Network Type: GSM SIM Status: ABSENT,REGIONAL_LOCKED Multisim Config: DSDS Knox Version: v00 Warranty Bit: 0 Security Patch: 2019-08-01 Data Encryption State: encrypted Reading codes online... The operation is in progress. Be patient! Do NOT disconnect the phone! Waiting for the server to respond. Master Lock: 31404196 Network Lock: 58185961 Subset Lock: 00000000 SP Lock: 00000000 CP Lock: 00000000 SIM Lock: 00000000 Successfully finished. Finished at local time: [12.15.19 11:54:15] WorkID: 82893255 |
12-16-2019, 18:13 | #3823 (permalink) |
Junior Member Join Date: Oct 2017 Location: bangladesh
Member: 2765662 Status: Offline Thanks Meter: 3 | SM-N950F Chimera Mobile Phone Utility Successfully Patch certificate Chimera Mobile Phone Utility version: 23.25.1456 @ 2019-12-16 Printing phone history Repair IMEI 12/16/2019 5:00:20 PM Rmm Unlock 12/16/2019 4:41:12 PM Repair IMEI 12/16/2019 12:39:13 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N950F Sales Code: H3G Country Code: UK Timezone: Asia/Dhaka Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Oct 1 11:54:19 KST 2019 PDA Version: N950FXXU7DSJ1 [october 2019, rev1] Phone Version: N950FXXU7ASG1 [july 2019, rev1] CSC Version: N950FCKH7DSJ1 [october 2019, rev1] Product Code: H3G HIDSw Version: N950FXXU7DSJ1/N950FCKH7DSJ1/N950FXXU7ASG1/N950FXXU7DSJ1 Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: R58K226TKNN Imei: 351018979xxxxx Unique Number: 988A16364D4E4B365330 Connections: AT,MTP Battery Status: 3.66V (10%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-10-01 Data Encryption State: unencrypted Preparing... Checking root access. The phone is rooted by: 3.14:EFTSU Reading data... Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [12.16.19 23:05:42] WorkID: 83027486 |
12-17-2019, 07:32 | #3824 (permalink) |
Member: 311558 Status: Offline Thanks Meter: 476 | a750fn repair log Chimera Mobile Phone Utility version: 23.25.1456 @ 2019-12-17 Printing phone history Patch Certificate 17.12.2019 06:17:36 Patch Certificate 16.12.2019 14:37:45 Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A750FN Sales Code: XSG Country Code: UAE Timezone: Europe/Istanbul Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Aug 27 19:55:20 KST 2019 PDA Version: A750FXXU2BSH8 [august 2019, rev8] Phone Version: A750FNXXU2ASH1 [august 2019, rev1] CSC Version: A750FOJM2BSH8 [august 2019, rev8] Product Code: XSG HIDSw Version: A750FXXU2BSH8/A750FOJM2BSH8/A750FNXXU2ASH1/A750FXXU2BSH8 Board Platform: EXYNOS5 Modem Platform: SHANNON327 Serial Number: RF8KB2BXPBJ Imei: 359776019074295 Unique Number: CCU00DF3FE80FB5 Connections: AT,MTP Battery Status: 3.83V (64%) Network Type: GSM SIM Status: LOADED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2019-09-01 Data Encryption State: unencrypted Preparing... Checking root access. The phone is rooted by: 3.17:EFTSU Reading data... Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [12.17.19 09:27:52] WorkID: 83083896 |
12-17-2019, 15:26 | #3825 (permalink) |
Member: 2742707 Status: Offline Thanks Meter: 138 | Chimera Mobile Phone Utility version: 23.25.1456 @ 2019-12-17 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G610F Sales Code: XFV Country Code: South Africa Timezone: Africa/Johannesburg Android Version: 6.0.1 [MMB29K] [SDK 23] Build Date: Wed Jul 19 14:49:08 KST 2017 PDA Version: G610FDDU1AQG2 [july 2017, rev2] Phone Version: G610FDDU1AQF4 [june 2017, rev4] CSC Version: G610FXFV1AQG1 [july 2017, rev1] Product Code: SM-G610FZDAXFV HIDSw Version: G610FDDU1AQG2/G610FXFV1AQG1/G610FDDU1AQF4/G610FDDU1AQG2 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: R58JB001KZA Imei: 350098787563337 Unique Number: CAJ00FEEFF4ABA4 Connections: AT,MTP Battery Status: 4.06V (66%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2017-07-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 2.82:SUPERSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. Reading boot image. Be patient! Do NOT disconnect the phone! Writing boot image. Be patient! Do NOT disconnect the phone! Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [12.17.19 16:24:13] |
