08-11-2023, 12:08 | #3 (permalink) |
Junior Member Join Date: Nov 2009 Location: Asgard
Member: 1151126 Status: Offline Thanks Meter: 1 | same issue face with me i am done many phones but sudenly 1 phone dead in conecting EUS i am not removing any lock just dead in conection dead boot also not work stuck on 25% br thailand Team |
08-11-2023, 12:25 | #4 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,782 | Dear User! What was the model number of the phone? Is it also an SM-A336E? And please also send us the workid. Best Regards, ChimeraTeam Last edited by Chimera Tool; 08-11-2023 at 12:38. |
08-14-2023, 13:24 | #6 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,782 | Dear User, Please create a virtual device in EUB mode then do a Boot Repair procedure. This should solve the issue. Best Regards, ChimeraTeam Last edited by Chimera Tool; 08-14-2023 at 13:33. |
08-14-2023, 17:53 | #7 (permalink) | |
Member: 1151126 Status: Offline Thanks Meter: 1 | Quote:
need to fix in next update pls process hang on 25% today also try work id - 230223345 | |
08-15-2023, 12:45 | #10 (permalink) |
Freak Poster Join Date: Mar 2023 Location: None Age: 44
Member: 3033926 Status: Offline Thanks Meter: 7 | Does disassembling the device, Disconnecting battery, Locating Test Point, Shorting it while connecting the device, Then selecting operation after detection help solving this problem? |
08-15-2023, 13:31 | #11 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,782 | Dear User, The problem in this thread is that the operation does not finish and gets stuck. Normally, it should work exactly as you mentioned. Best Regards, ChimeraTeam |
The Following 4 Users Say Thank You to Chimera Tool For This Useful Post: |
04-14-2024, 19:34 | #12 (permalink) |
Junior Member Join Date: Jul 2009 Location: in ethiopia
Member: 1077427 Status: Offline Sonork: 12343 Thanks Meter: 3 | chimera tool kill A33 5g when trying to unlock frp Chimera Mobile Phone Utility version: 39.07.0945 @ 2024-04-14 Boot Repair Extracting firmware Extracting BL_A336BXXS8DXA1_A336BXXS8DXA1_MQB75832551_REV00_u ser_low_ship_MULTI_CERT.tar.md5 Processing firmware Firmware was successfully processed Firmware was successfully processed Connecting to the phone... Repairing phone Repairing... Rebooting... An error occurred during the procedure! Finished at local time: [04.14.24 21:17:44] WorkID: 270724411 Last edited by shamsu200; 04-14-2024 at 19:36. Reason: and cannot repair |
The Following User Says Thank You to shamsu200 For This Useful Post: |
04-17-2024, 21:28 | #14 (permalink) |
Freak Poster Join Date: Jun 2015 Location: Vanuatu/ Philippines Age: 43
Member: 2418465 Status: Offline Thanks Meter: 23 | the culprit why it killed all a33 5g, because entering in eub mode requires files to be written on the phone, perhaps chimera can figured out the problem, otherwise much better to remove this a33 in their software to avoid future problems, because a lot of users are complaining |
04-18-2024, 09:52 | #15 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,782 | Dear User, First of all, NOT all A33 5G devices are "killed" in EUB mode, only those are "killed" where the re-connection of the battery is done at the inappropriate time, thus shorting the whole phone. Because of this, we won't remove this phone from the supported models list. Secondly, testpointing a device and connecting the battery at the wrong time, cannot be solved by us. Regards, ChimeraTeam Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
