02-07-2017, 18:50 | #1501 (permalink) |
Freak Poster Join Date: Feb 2011 Location: colombia
Member: 1514183 Status: Offline Thanks Meter: 33 | [Development Support] Searching for Manufacture port... Working on it... Searching for Manufacture port... Working on it... Process finished. Thank you for your support! Reboot the device... Finished successfully. Finished at local time: [02.07.17 12:47:13] WorkID: 17738959 repair 1m31 [Repairing IMEI(s)...] Searching for Manufacture port... Checking IMEI(s)... Repairing first IMEI... This may take a while. Be patient! Do NOT disconnect the phone! Synchronizing EFS... Resetting device to factory state... Finished successfully. Finished at local time: [02.07.17 12:50:19] WorkID: 17739118 |
02-07-2017, 19:31 | #1502 (permalink) |
Member: 1514183 Status: Offline Thanks Meter: 33 | d855p briked [Firmware Update started] Downloading firmware... Firmware downloaded successfully Preparing firmware files... Changing to download mode ... Waiting for download mode serial port to appear... Flashing firmware ... USB Connection Established Waiting for reset 40 sec Finished successfully. Flashing: MODEM Flashing: SBL1 Flashing: ABOOT Flashing: RPM Flashing: TZ Flashing: BOOT Flashing: PERSIST Flashing: RECOVERY Flashing: RCT Flashing: LAF Flashing: FACTORY Flashing: SYSTEM Finished at local time: [02.07.17 13:23:37] WorkID: 17739768 |
The Following User Says Thank You to THE FIXCEL For This Useful Post: |
02-07-2017, 21:49 | #1503 (permalink) |
Member: 1514183 Status: Offline Thanks Meter: 33 | repair 1m31 b5330l invalid Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: GT-B5330L Sales Code: COM Country Code: COLOMBIA Timezone: America/Bogota Android Version: 4.1.2 [JZO54K] Build Date: Mon Oct 21 20:21:53 KST 2013 PDA Version: B5330LUBUBMJ1 [october 2013, rev1] Phone Version: B5330LUBUBMJ1 [october 2013, rev1] CSC Version: B5330LUWABMJ1 [october 2013, rev1] Product Code: GT-B5330ZWLCOM HIDSw Version: B5330LUBUBMJ1/B5330LUWABMJ1/B5330LUBUBMJ1/B5330LUBUBMJ1 Board Platform: RHEA Serial Number: R21F17WF98D Imei: 353246052496454 Connections: AT,MTP Battery Status: 3.83V (11%) Network Type: GSM SIM Status: ABSENT Rooting by generic root method 2... Rooting in progress. Be patient! Do NOT disconnect the phone! Root method failed. Rooting by generic root method... Checking root state... Rooted. Repairing imei... Check the phone's display during the process! Imei repaired. New imei: 353246057796452 Finished successfully. Finished at local time: [02.07.17 15:48:18] WorkID: 17746806 |
02-07-2017, 22:17 | #1504 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Flash LG H221AR Chimera Versión de la Mobile Phone Utility: 12.80.1419 @ 2017-02-07 Printing phone history Info 7/2/2017 9:02:51 p. m. [Firmware Update started] Downloading firmware... Firmware downloaded successfully Preparing firmware files... Changing to download mode ... Waiting for serial port to appear... Trying to boot the phone into download mode... Waiting for download mode serial port to appear... Flashing firmware ... USB Connection Established Waiting for reset 60 sec Finalizing Finished successfully. Flashing: MODEM Flashing: SBL1 Flashing: RPM Flashing: TZ Flashing: SDI Flashing: ABOOT Flashing: PERSIST Flashing: LAF Flashing: BOOT Flashing: RECOVERY Flashing: FACTORY Flashing: SYSTEM Finished at local time: [02.07.17 18:12:51] WorkID: 17747430 |
02-07-2017, 22:21 | #1505 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Unlock LG H221AR Chimera Versión de la Mobile Phone Utility: 12.80.1419 @ 2017-02-07 [Direct Unlock started] Before this procedure it is recommended to create an EFS backup. Do you want to create a backup? Creating EFS backup... Waiting for serial port to appear... Trying to boot the phone into download mode... Waiting for download mode serial port to appear... Reading EFS partitions. Do not disconnect the phone! EFS data saved successfully! Rebooting phone into normal mode... Checking ports For unlock, a DIAG mode serial must be present. Searching for ports Waiting for diag serial port to appear...  Please make sure 'Port Check Test' is enabled on the phone! How to enable 'Port Check Test' or 'DIAG port' on your LG phone: There are many different ways to enable this option, but not all of them will work on all phones. Try them out one-by-one  Dial in the following codes on your phone (without pressing call). If the code works a hidden menu will apear. Find the option 'Port Check Test', and set it to 'Enabled'. It is usually in the top menu or in the 'SVC Menu' submenu. 277634#*# 3845#*221# *#546368#*221# In case you can not get to the hidden menu, or the hidden menu does not contain the option 'Port Check Test', try Factory Reset on the phone. DIAG mode serial found. Waiting for ADB connection.Be patient! Do NOT disconnect the phone! Unlocking Phone IMEI is correct.: 359977060878416 Unlocked. Restarting phone... Finished successfully. Finished at local time: [02.07.17 18:20:06] WorkID: 17748047 |
02-07-2017, 23:10 | #1506 (permalink) |
Member: 1514183 Status: Offline Thanks Meter: 33 | [Firmware update started] Selected model: SM-G318ML Processing firmware... Flashing firmware... Waiting for download mode. Connecting. Reading PIT. Flashing boot.img Flashing recovery.img Flashing system.img Flashing spl.img Flashing sboot.bin Flashing sboot2.bin Flashing param.lfs Flashing SPRDCP.img Flashing SPRDDSP.img Flashing nvitem.bin Flashing cache.img Flashing hidden.img Restarting phone. Finished successfully. Finished at local time: [02.07.17 17:09:03] WorkID: 17749632 |
02-09-2017, 10:29 | #1507 (permalink) |
No Life Poster Join Date: Feb 2010 Location: Macedonia Age: 49
Member: 1246981 Status: Offline Sonork: 100.1590424 Thanks Meter: 316 | s6500d flashing done Chimera Mobile Phone Utility version: 12.80.1419 @ 2017-02-09 Printing phone history SW Change 07-Feb-17 11:27:42 SW Change 23-Jan-17 19:13:01 SW Change 23-Jan-17 13:23:19 SW Change 20-Jan-17 10:06:20 Reset FRP Lock 20-Jan-17 09:16:04 [Firmware update started] Selected model: GT-S6500D Extracting firmware... Unzipping firmware: S6500DXXMH1_S6500DXXMH1_S6500DMBMMH2_HOME.tar.md5. Processing firmware... Flashing firmware... Waiting for download mode. Connecting. Reading PIT. Flashing system.img.ext4 Flashing boot.img Flashing recovery.img Flashing fat.bin Flashing cache.img.ext4 Flashing hidden.img.ext4 Restarting phone. Finished successfully. Finished at local time: [02.09.17 10:26:18] WorkID: 17797744 |
02-09-2017, 11:06 | #1508 (permalink) |
Member: 1246981 Status: Offline Sonork: 100.1590424 Thanks Meter: 316 | huawei y6 scl-l01 frp remove done Chimera Mobile Phone Utility version: 12.80.1419 @ 2017-02-09 [Removing factory reset protection...] Collecting information about the device... Trying to remove factory reset protection lock... This did not work, trying some other ways... Checking if we need to do some magic... Reading secret... Calculating some magic from the secret... This may take a while. Be patient! Do NOT disconnect the phone! Sending magic to the device... Checking if the magic succeed... Wiping device... Finished successfully. Finished at local time: [02.09.17 11:05:06] WorkID: 17798659 |
02-09-2017, 11:22 | #1509 (permalink) |
Member: 1246981 Status: Offline Sonork: 100.1590424 Thanks Meter: 316 | huawei y6 scl-l01 unlock done [Removing network lock...] Searching for Manufacture port... Automatic Manufacture Port enabling... Authenticating... This may take a while. Be patient! Do NOT disconnect the phone! Clearing network lock... This may take a while. Be patient! Do NOT disconnect the phone! Finished successfully. Finished at local time: [02.09.17 11:21:04] WorkID: 17799059 |
02-09-2017, 15:07 | #1510 (permalink) |
No Life Poster Join Date: Apr 2008 Location: gsmsolution Age: 34
Member: 755480 Status: Offline Sonork: 100.1609798 Thanks Meter: 233 | Code: Chimera Mobile Phone Utility version: 12.80.1419 @ 2017-02-09 Printing phone history Info 2/9/2017 1:34:22 PM [Read codes started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G610F Sales Code: KSA Country Code: KSA Timezone: Asia/Colombo Android Version: 6.0.1 [MMB29K] Build Date: Wed Dec 28 15:04:12 KST 2016 PDA Version: G610FDDU1APLC [december 2016, revC] Phone Version: G610FDDU1API9 [september 2016, rev9] CSC Version: G610FOJV1APJ2 [october 2016, rev2] Product Code: SM-G610FZDDKSA HIDSw Version: G610FDDU1APLC/G610FOJV1APJ2/G610FDDU1API9/G610FDDU1APLC Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: R28HC03VVPB Imei: 353111086090188 Unique Number: CAJ033D0C58DAB3 Connections: AT,MTP Battery Status: 4.11V (81%) Network Type: GSM SIM Status: NETWORK_LOCKED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2016-10-01 Reading Codes... Please unlock screen lock if closed! Trying on SAMSUNG Mobile USB Modem (COM93) Processing. Be patient! Do NOT disconnect the phone! Please unlock screen lock if closed! Calculating. MasterLock: 31936294 NetworkLock: 63191605 SubsetLock: 00000000 SpLock: 00000000 CpLock: 00000000 SimLock: 00000000 Finished successfully. Finished at local time: [02.09.17 19:13:16] WorkID: 17805332 |
02-09-2017, 21:52 | #1511 (permalink) |
Member: 1514183 Status: Offline Thanks Meter: 33 | ji 2016 root [Rooting phone started] Checking custom root image... Descargando imagen personalizada de root. Be patient! Do NOT disconnect the phone! Checking downloaded image. Present. Rooting by custom image based root method... Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. Reading PIT. Flashing boot.img Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Checking root state... Rooted. Disabling knox. Be patient! Do NOT disconnect the phone! Knox disabled. Finished successfully. Finished at local time: [02.09.17 15:50:59] WorkID: 17823125 |
02-10-2017, 11:41 | #1512 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | LG G4 (LG-H812) done. [Direct Unlock started] Before this procedure it is recommended to create an EFS backup. Do you want to create a backup? Creating EFS backup... Waiting for serial port to appear... Trying to boot the phone into download mode... Waiting for download mode serial port to appear... Reading EFS partitions. Do not disconnect the phone! EFS data saved successfully! Rebooting phone into normal mode... Checking ports For unlock, a DIAG mode serial must be present. Searching for ports Waiting for diag serial port to appear...  Please make sure 'Port Check Test' is enabled on the phone! How to enable 'Port Check Test' or 'DIAG port' on your LG phone: There are many different ways to enable this option, but not all of them will work on all phones. Try them out one-by-one  Dial in the following codes on your phone (without pressing call). If the code works a hidden menu will apear. Find the option 'Port Check Test', and set it to 'Enabled'. It is usually in the top menu or in the 'SVC Menu' submenu. 277634#*# 3845#*812# *#546368#*812# In case you can not get to the hidden menu, or the hidden menu does not contain the option 'Port Check Test', try Factory Reset on the phone. DIAG mode serial found. Unlocking Phone IMEI is correct.: 359803065508941 Unlocked. Restarting phone... Finished successfully. Finished at local time: [๐๒.๑๐.๑๗ ๑๗:๓๗:๓๐] WorkID: 17835289 |
02-10-2017, 14:09 | #1513 (permalink) |
Member: 755480 Status: Offline Sonork: 100.1609798 Thanks Meter: 233 | j320fn read code done (no root) Code: [Read codes started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J320FN Sales Code: PHN Country Code: The Netherlands Timezone: Asia/Colombo Android Version: 5.1.1 [LMY47V] Build Date: Mon Aug 1 18:36:14 KST 2016 PDA Version: J320FNXXU0APH1 [august 2016, rev1] Phone Version: J320FNXXU0APH1 [august 2016, rev1] CSC Version: J320FNPHN0API3 [september 2016, rev3] Product Code: SM-J320FZWNPHN HIDSw Version: J320FNXXU0APH1/J320FNPHN0API3/J320FNXXU0APH1/J320FNXXU0APH1 Board Platform: SC8830 Modem Platform: SC9830I Serial Number: RF8HB2X3CMX Imei: 355099082094460 Unique Number: CQN006792EEE5B3 Connections: AT,MTP Battery Status: 4.00V (64%) Network Type: GSM SIM Status: NETWORK_LOCKED Warranty Bit: unknown Security Patch: 2016-08-01 Reading Codes... Trying on modem port SAMSUNG Mobile USB Modem (COM47) Trying on modem port SAMSUNG Mobile USB Modem (COM107) Freeze Code: 79142059 Network Lock: 90907249 Subset Lock: 00000000 SP Lock: 00000000 CP Lock: 00000000 SIM Lock: 00000000 Finished successfully. Finished at local time: [02.10.17 18:35:28] WorkID: 17839239 |
02-10-2017, 15:22 | #1514 (permalink) |
Member: 755480 Status: Offline Sonork: 100.1609798 Thanks Meter: 233 | lh h340n screen lock remove without data lose just in one click |
The Following User Says Thank You to danisajee For This Useful Post: |
02-10-2017, 23:08 | #1515 (permalink) |
Member: 1514183 Status: Offline Thanks Meter: 33 | Chimera Versión de la Mobile Phone Utility: 12.89.0901 @ 2017-02-10 [Removing factory reset protection...] Collecting information about the device... Trying to remove factory reset protection lock... This did not work, trying some other ways... Checking if we need to do some magic... Reading secret... Calculating some magic from the secret... This may take a while. Be patient! Do NOT disconnect the phone! Sending magic to the device... Checking if the magic succeed... Wiping device... Finished successfully. Finished at local time: [02.10.17 17:05:19] WorkID: 17860406 |
