11-03-2017, 13:34 | #1 (permalink) |
Major Poster Join Date: Nov 2014
Member: 2298759 Status: Offline Thanks Meter: 2 | Chimeratool cannot unlock SM-J327P (UNLOCK fAILED) [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J327P Sales Code: BST Country Code: USA Timezone: Pacific/Tongatapu Android Version: 6.0.1 [MMB29M] Build Date: Tue Sep 12 09:15:24 KST 2017 PDA Version: J327PVPU2AQI2 [september 2017, rev2] Phone Version: J327PVPU1AQF4 [june 2017, rev4] CSC Version: J327PSPT2AQI2 [september 2017, rev2] Product Code: XXXXXXXXXXXBST HIDSw Version: J327PVPU2AQI2/J327PSPT2AQI2/J327PVPU1AQF4/J327PVPU2AQI2 Board Platform: MSM8937 Modem Platform: MSM8917 Serial Number: 00000000000 Imei: 359102084455469 Unique Number: CQ300F1A3E42764 Connections: AT,MTP Battery Status: 4.33V (100%) Network Type: CDMA SIM Status: CARD_IO_ERROR Knox Version: v30 Warranty Bit: 1 Security Patch: 2017-08-01 Data Encryption State: encrypted Unlocking... Processing. Be patient! Do NOT disconnect the phone! Root permission required. Trying to root... Trying again. Be patient! Do NOT disconnect the phone! Unable to unlock. Finished at local time: [11.04.17 01:28:46] WorkID: 28708933 |
11-03-2017, 14:03 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Dear Sir! Please! use this version: Android Version: 6.0.1 [MMB29M] Build Date: Mon Feb 27 14:26:02 KST 2017 PDA Version: J327PVPU1AQB6 [february 2017, rev6] Phone Version: J327PVPU1AQB6 [february 2017, rev6] CSC Version: J327PSPT1AQB6 [february 2017, rev6] [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J327P Sales Code: XAS Country Code: USA Timezone: America/New_York Android Version: 6.0.1 [MMB29M] Build Date: Mon Feb 27 14:26:02 KST 2017 PDA Version: J327PVPU1AQB6 [february 2017, rev6] Phone Version: J327PVPU1AQB6 [february 2017, rev6] CSC Version: J327PSPT1AQB6 [february 2017, rev6] Board Platform: MSM8937 Modem Platform: MSM8917 Serial Number: 00000000000 Imei: 356964082070282 Battery Status: 3.67V (6%) Network Type: CDMA SIM Status: READY Knox Version: v30 Warranty Bit: 1 Security Patch: 2017-02-01 Data Encryption State: encrypted Unlocking... Processing. Be patient! Do NOT disconnect the phone! Unlocked. Finished successfully. Finished at local time: [07.26.17 10:38:43] WorkID: 24241376 |
11-03-2017, 14:12 | #3 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Root j327P USB Debbugging and OEM Unlock 1. "AP" and select the file "twrp_3.1.0-1_j327p_14317.tar" in the RECOVERY folder. 2. Important this: make sure that ONLY the box F. Reset Time is selected and nothing else in the "Options" tab 3. Click on Start and wait for the process to finish. 4. Once you say PASS in a green box, disconnect the phone. 5. Send the file "SR3-SuperSU-v2.79-SR3-20170114223742.zip" that is inside the SUPERSU folder to an SD card and connect it to the mobile. 6. Remove the battery, replace it and start the Recovery mode (Volume plus + Home + Power) 7. Once in Recovery, select the "Install" box and then the box "Select storage" choose "Micro SD card" and then choose the file from the SUPERSU folder that we sent to the SD card. 8. When finished click "Restart system." twrp_3.1.0-1_j327p_14317.tar https://androidfilehost.com/?fid=745425885120715171 SR3-SuperSU-v2.79-SR3-20170114223742.zip https://androidfilehost.com/?fid=745425885120700896 |
11-03-2017, 16:17 | #4 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,744 | reply Dear Sir, we have lot of successfully unlock on the same model, please try to install other firmware on the device and root it. When the mentioned instructions are done, please try again the unlock process. Best regards Nicole Quote:
11-03-2017, 22:14 | #5 (permalink) | |
Member: 2298759 Status: Offline Thanks Meter: 2 | Downgrading via Odin keeps failing Quote:
11-03-2017, 22:17 | #6 (permalink) | |
Member: 2298759 Status: Offline Thanks Meter: 2 | Already Rooted via Twrp..Unlock stil fail Quote:
11-03-2017, 22:34 | #7 (permalink) |
Member: 2298759 Status: Offline Thanks Meter: 2 | Sorry, I have Already rooted it via twrp and stil fail...I already tried flashing other other earlier firmwares to it via odin but it does not accept the other firmwares...I have unlocked SM-J327P Security Patch Level 2017-02-01... But this SM-J327P I have Now is Security Patch: 2017-08-01 and is the one that keeps failing. ...Please help is there any other methods??? |
12-26-2017, 04:15 | #8 (permalink) |
Junior Member Join Date: Jan 2007
Member: 425880 Status: Offline Thanks Meter: 0 | J327P unlock on augustu 2017 security yes you are right, it does not work. I believe we have to wait for new updates from Chimera and other unlockers to make it possible. I have tried root, downgrade which as you said does not work. This update does not allow downgrade, at least I could not do that. It will just be a wastage of time as I spent whole day trying to unlock them b ut in vain. Only one unlocking is June 2017 version without any problem. I will request chimera team to work on this security patch and help. So many peope are waiting for that. |
12-26-2017, 12:12 | #9 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, updates will be launched after christmas eve, please be patient some updates require develop and test.... Best Regards Shensohau |
08-26-2018, 03:04 | #12 (permalink) |
Freak Poster Join Date: Jun 2015
Member: 2405718 Status: Offline Thanks Meter: 14 | Hi, Did this ever got resolved? Unlock for this device.. Managed to flash J327PVPU4ARG2 as OTA update was blocking provided FW via Chimera. Code: [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J327P Timezone: Pacific/Tarawa Android Version: 6.0.1 [MMB29M] [SDK 23] Build Date: Mon Jul 9 16:43:24 KST 2018 PDA Version: J327PVPU4ARG2 [july 2018, rev2] Phone Version: J327PVPU3AQL3 [december 2017, rev3] Board Platform: MSM8937 Modem Platform: MSM8917 Serial Number: 00000000000 Imei: 35910208171852 Battery Status: 4.17V (93%) Network Type: CDMA SIM Status: ABSENT Knox Version: v30 Warranty Bit: 1 Security Patch: 2018-07-01 Data Encryption State: encrypted Unlocking... Processing. Be patient! Do NOT disconnect the phone! Unable to unlock. Finished at local time: [08.26.18 13:54:52] WorkID: 43021943 Last edited by karotu; 08-26-2018 at 03:05. Reason: wrong code |
08-27-2018, 16:49 | #13 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,744 | reply Dear User, The u3 and u4 versions are not supported yet. Currently the Chimera tool can handle the u1 version! Of course that will be updated , but for that fix we will need a little time. Thank you for your understanding. Best Regards Chimera Team Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
