Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 03-09-2019, 04:39   #16 (permalink)
Member: 2320327
Thanks Meter: 32
Originally Posted by the_phant View Post
Chimera team, you can see another log with PATH CERTIF OK, although the status of the imei is still NG, please help find a solution so that the network of the mobile device can work ... thank you very much
best regards
The_Phantomas
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-J600G
Sales Code: UFN
Country Code: Argentina
Timezone: America/Argentina/Buenos_Aires
Android Version: 8.0.0 [R16NW] [SDK 26]
Build Date: Tue May 15 00:54:37 KST 2018
PDA Version: J600GUBU1ARE5 [may 2018, rev5]
Phone Version: J600GDXU1ARDH [april 2018, revH]
CSC Version: J600GOWT1ARE7 [may 2018, rev7]
Product Code: UFN
HIDSw Version: J600GUBU1ARE5/J600GOWT1ARE7/J600GDXU1ARDH/J600GUBU1ARE5
Board Platform: EXYNOS5
Modem Platform: SHANNON315
Serial Number: R28K8xxxxxx
Imei: 35922509xxxxxxx
Unique Number: CBJ0034Fxxxxxxx
Connections: AT,MTP
Battery Status: 3.71V (10%)
Network Type: GSM
SIM Status: READY
Multisim Config: SS
Knox Version: v30
Warranty Bit: 0
Security Patch: 2018-05-01
Data Encryption State: unencrypted
Preparing...
Checking current patchcert.
Checking modem.
Checking root.
Checking boot image. Be patient! Do NOT disconnect the phone!
The knox is still valid. Because of the boot patch the warranty will void.
Writing boot image.
Restarting phone.
Waiting for ADB connection. Be patient! Do NOT disconnect the phone!
Reading data...
Checking modem version.
Restarting phone.
Reading data. Be patient! Do NOT disconnect the phone!
Patching certificate...
Communicating with the server. Be patient! Do NOT disconnect the phone!
Within 20-70 seconds after the phone starts, the signal strength indicator will toggle: signal -> no signal -> signal.
You can check the status of the imei using: *#0011#
The patchcert can be removed by repeating the process.
If a new firmware is used, the patchcert process must be repeated.
Succeeded.
Successfully finished.
Finished at local time: [03.08.19 00:28:00]
WorkID: 54247395
the problem is that you use magisk to root the phone, the patch cert work only if you use supersu that grant full access to the phone. The correct to root the phone is flash no verify opt.zip, then use supersu 2.82 sr3. use security patch september or november to work perfect.
Old 03-09-2019, 09:19   #17 (permalink)
Member: 1812784
Thanks Meter: 45
supersu 2.82 sr dont work on j6
Old 03-13-2019, 11:16   #18 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
hey..
r u sure that this device has accept supersu.? i think it is not..if u flash the supersu after no verfiy opt zip device is not power on and bootloop..
Page generated in 0.12981 seconds with 8 queries
