03-03-2015, 13:45 | #1 (permalink) |
Product Supporter Join Date: Dec 2010 Location: Brazil Fortaleza Ceará
Member: 1474113 Status: Offline Sonork: 100.1604217 Thanks Meter: 472 | Errors regarding read and write chimera certificate file - SOLVED Please report your problems to Read and Write certificate files with Chimera tool. Any other unrelated segments will be deleted. Thank Sincerely, Team Chimera Last edited by paulo pessoa; 03-09-2016 at 18:02. |
03-03-2015, 13:58 | #2 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,718 | Reply Dear Users, Please use this topic only if you have problems with ChimeraTool CERT Read/Write function. If you have any problems, please search for the related topic, every thread which can not be connected with CERT Read/Write procedure will be deleted. If you would like to share CERT files for Samsung devices, please use this section: http://forum.gsmhosting.com/vbb/f898...atool-1920257/ Thank you! Best Regards, Chimera Team |
03-04-2015, 16:52 | #6 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,718 | reply Dear cobaltodaniel, This is a kind of EFS problem. Basically Cert write procedure can fix this problem, if not, than the phone's modem is broken. Unfortunately hardware problems ChimeraTool can not solve and this is a hardware issue. Please take your device to a shop nearby where they are dealing with phone's hardware repairing. Best Regards, Chimera Team Last edited by Chimera Tool; 03-04-2015 at 17:09. |
03-05-2015, 13:25 | #8 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,718 | reply Dear cobaltodaniel, Actually our development team is working on a solution which will be able to repair those phones as well what current procedure can not. So please just be patient until we figure it out and let everyone know once it is done. Best Regards, Chimera Team |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
03-20-2015, 22:13 | #9 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2309708 Status: Offline Thanks Meter: 2 | That's something that has to do with the program. I tried with 3 new galaxy s5. And the 3 marks error: "ha" The 3 phones operate at 100% and have no problem. 3 used to read the certificate. All 3 have Android 5.0 Lollipop. Will issue with Android 5.0? |
03-23-2015, 10:22 | #10 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,718 | reply Dear jotademanuel507, We are working on the solution, android version 5.0 has a different coding. Please give us some time to create the support for the latest Android version. Please do not make EFS Reset, because it can brick your phone and can not be used anymore. Best Regards, Chimera Team |
10-03-2015, 13:58 | #11 (permalink) |
Freak Poster Join Date: Nov 2007 Location: Bangladesh
Member: 638097 Status: Offline Sonork: 100.1649741 Thanks Meter: 43 | Read Write Cert Failed Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G925F Android Version: 5.1.1 Sales Code: EUR PDA Version: G925FXXU2COH2 [august 2015, rev2] Phone Version: G925FXXU2COH2 [august 2015, rev2] CSC Version: G925FEUR2COH3 [august 2015, rev3] Product Code: SM-G925FZDAEUR HIDSw Version: G925FXXU2COH2/G925FEUR2COH3/G925FXXU2COH2/G925FXXU2COH2 Board Platform: EXYNOS5 Serial Number: RF8G42BN1LB Imei: 359521063704896 Unique Number: 04157DF4AB604417 Connections: AT,MTP Battery Status: 4.32V (96%) SIM Status: ABSENT Knox Version: v30 Warranty Bit: 1 Writing cert to phone... Reading and storing secure image. Checking secure image. Preparing. Calculating. Be patient! Do NOT disconnect the phone! Invalid keys. Unable to write cert. Finished at local time: [10.03.15 15:57:14] WorkID: 7220187 |
10-05-2015, 09:15 | #12 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,718 | reply Dear Sir, We know this problem. The phone can not reach the necessary files. The developer team are working on this problem already. Best Regards Chimera Team Quote:
10-12-2015, 09:40 | #13 (permalink) |
Junior Member Join Date: Jan 2008
Member: 682092 Status: Offline Thanks Meter: 1 | Cert / read write I am having the same as above problem SM-G920F. The phone previously read and written cert files to the phone, now it's reporting "invalid Keys" error Do you have a timescale for this? regards, p.s. I hope you get problem sorted. Also I have noticed that in phone info/status section: the security software vertsion is MDF v2.0 release 3 and VPN x1.4 release 5 maybe this is causing something as this was earlier version before... noyt sure how it got updated! |
10-12-2015, 10:19 | #14 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,718 | reply Dear Sir, maybe could you send us work id please? It will be helpful for us. Thank you Best regards Nicole Chimera Team Quote:
