03-27-2016, 01:49 | #31 (permalink) |
Crazy Poster Join Date: May 2008 Location: venezuela
Member: 770051 Status: Offline Thanks Meter: 1 | Error gt-i9500 Collecting information. Be patient! Do NOT disconnect the phone! Model: GT-I9500 Sales Code: TFG Country Code: OPEN Timezone: America/Caracas Android Version: 5.0.1 [LRX22C] Build Date: Fri Nov 20 05:08:16 KST 2015 Security Patch: 2015-11-01 PDA Version: I9500UBUHOK2 [november 2015, rev2] Phone Version: I9500UBUHOK1 [november 2015, rev1] CSC Version: I9500TFGHOK1 [november 2015, rev1] Board Platform: EXYNOS5 Modem Platform: XMM6360 Serial Number: 00000000000 Imei: 004999010640000 Battery Status: 3.76V (13%) Network Type: GSM SIM Status: ABSENT Knox Version: v30 Warranty Bit: 1 Determining secure image format. done. Creating backup. done. Gathering cert informations done. Calculating key. done. Saving certificate. Trying to repair secure block. Checking secure image. Writing secure image. done. Checking secure image. Writing secure image. done. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Writing image. Current IMEI checksum error! Checking secure image. Writing secure image. done. Restarting phone. Finished successfully. Finished at local time: [03.26.16 20:17:33] WorkID: 9965837 |
03-30-2016, 13:42 | #34 (permalink) |
Junior Member Join Date: Mar 2010
Member: 1271288 Status: Offline Sonork: zabuhari Thanks Meter: 2 | Pls Help ME Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G925F Sales Code: NEE Country Code: Nordic Timezone: Africa/Lagos Android Version: 5.0.2 [LRX22G] Build Date: Wed May 6 17:06:58 KST 2015 PDA Version: G925FXXU1AOE3 [may 2015, rev3] Phone Version: G925FXXU1AOE3 [may 2015, rev3] CSC Version: G925FNEE1AODO [april 2015, revO] Board Platform: EXYNOS5 Modem Platform: SHANNON333 Serial Number: RF8G61VNJ3J Imei: 350000000000006 Battery Status: 3.85V (46%) Network Type: GSM SIM Status: READY Knox Version: v30 Warranty Bit: 0 Reading cert from phone... Reading secure image. Checking secure image. Unable to read cert. Finished at local time: [03.30.16 13:37:29] WorkID: 10016678 |
03-30-2016, 14:26 | #35 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,746 | reply Dear Sir, Nvdata corrupted, because of this the process will be unsuccessful. at the moment we can not repair the mentioned Nvdata error. Best regards Nicole Quote:
04-02-2016, 02:33 | #38 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1012080 Status: Offline Thanks Meter: 0 | uart cable problem, write cert N9005 problem. hello everyone, I have a problem with notes 3 , N9005 to write Cert file , I have a fully functional uart cable, I tried with resistor and 530kohm 639kohm no results . The cable works because tested on s3mini . What could it be? I should try other resistances and some settings on smartphones . ? thank you |
04-02-2016, 02:33 | #39 (permalink) |
Member: 1012080 Status: Offline Thanks Meter: 0 | Errors regarding read and write chimera certificate file hello everyone, I have a problem with notes 3 , N9005 to write Cert file , I have a fully functional uart cable, I tried with resistor and 530kohm 639kohm no results . The cable works because tested on s3mini . What could it be? I should try other resistances and some settings on smartphones . ? thank you |
04-02-2016, 13:46 | #40 (permalink) | |
Product Supporter Join Date: Dec 2010 Location: Brazil Fortaleza Ceará
Member: 1474113 Status: Offline Sonork: 100.1604217 Thanks Meter: 472 | Quote:
04-02-2016, 17:49 | #41 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: Now on earth Age: 48
Member: 75290 Status: Offline Thanks Meter: 57 | write cert file to SM-G531F Quote: Another tools are doing this. So I ask when will possible to do this with Chimera? BR ERSA Seb | |
04-04-2016, 10:35 | #42 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,746 | reply Dear Sir, have you teamviewer? can we check what happened when you try to use the uart cable for the process? If it is possible, please contact us in private message, thank you in advance! Best regards Nicole Quote:
05-04-2016, 12:04 | #43 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Lithuania Age: 44
Member: 16237 Status: Offline Thanks Meter: 30 | How about draining battery after read/write cert? Like I posted in forum about rooting/writing/reading cert: http://forum.gsmhosting.com/vbb/f898...6edge-2083054/ Is it possible repair this bug??? |
05-04-2016, 15:27 | #44 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,746 | reply Dear Sir, at the moment the mentioned error under review. Our developer team try to detect, what is a reason of the battery problem. We will create here an post about the result as soon as possible. Best regards Nicole Quote:
06-17-2016, 00:46 | #45 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | samsung n910u can not write cert always fail Hi team plz check and tell me what going on why i get this error Code: [Read/Write certificate started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N910U Sales Code: NZC Country Code: New Zealand Timezone: Pacific/Auckland Android Version: 5.1.1 [LMY47X] Build Date: Tue Dec 15 13:47:04 KST 2015 PDA Version: N910UXXU2COL2 [december 2015, rev2] Phone Version: N910UXXU1COL1 [december 2015, rev1] CSC Version: N910UNZC2COL1 [december 2015, rev1] Product Code: SM-N910UZKENZC HIDSw Version: N910UXXU2COL2/N910UNZC2COL1/N910UXXU1COL1/N910UXXU2COL2 Board Platform: EXYNOS5 Modem Platform: XMM7260 Serial Number: R28G60HPRPE Imei: 3567720++++++++ Unique Number: CR2004421570012 Connections: AT,MTP Battery Status: 3.68V (29%) Network Type: GSM SIM Status: READY Knox Version: 0 Warranty Bit: 1 Security Patch: 2015-12-01 Determining secure image format. done. Creating backup. done. Gathering cert informations done. Calculating key. Chtool app run failed! Finished at local time: [06.17.16 11:45:23] WorkID: 11499290 |
