10-01-2018, 15:08 | #91 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,766 | reply the device's modem damaged, it is a reason why the process can not be done. Try to ref lash with complete stock firmware, maybe it can solve the problem. (Imei: 350000000000006) Best regards Nicole Quote:
01-14-2019, 12:10 | #95 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,766 | reply Hi, it is an dual cert file and each cert added into 1 file. We have that file too, and we uploaded it for you in 2 difference file, please use them. https://mega.nz/#!ZtJFBC5B!OPuBqpbZZ...B2nAGkf3mGH9sk On the other hand, it is an j320f CERT, but your device is a320f. Please do check it again. Best regards Nicole |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
05-19-2019, 12:19 | #96 (permalink) |
Junior Member Join Date: Mar 2019 Location: Pakistan
Member: 2902239 Status: Offline Thanks Meter: 6 | PLease Help Write certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: GT-I9301I Sales Code: KSA Country Code: KSA Timezone: Asia/Karachi Android Version: 4.4.2 [KOT49H] [SDK 19] Build Date: Thu Aug 14 19:45:05 KST 2014 PDA Version: I9301IXXUANH2 [august 2014, rev2] Phone Version: I9301IXXUANF2 [june 2014, rev2] CSC Version: I9301IOJVUANH1 [august 2014, rev1] Product Code: GT-I9301MBIITV HIDSw Version: I9301IXXUANH2/I9301IOJVUANH1/I9301IXXUANF2/I9301IXXUANH2 Board Platform: MSM8226 Modem Platform: MSM8228 Serial Number: RV1F63295LK Imei: 352750061642470 Unique Number: C16040D6ACB5811 Connections: AT,MTP Battery Status: 3.99V (60%) Network Type: GSM SIM Status: UNKNOWN Knox Version: v00 Warranty Bit: 0 Data Encryption State: unencrypted Resetting MSL... Trying on SAMSUNG Mobile USB Serial Port (COM56) MSL reset. Writing cert via USB... Cert write is in progress. Be patient! Do NOT disconnect the phone! Cert write failed. Finished at local time: [05.19.19 04:12:46] WorkID: 60066784 |
05-20-2019, 14:40 | #97 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,766 | reply Hi, re-flash your device or try to use other cert file. Best regards Nicole Quote:
07-31-2019, 16:56 | #98 (permalink) | |
Insane Poster Join Date: Dec 2013 Location: dubai
Member: 2083552 Status: Offline Thanks Meter: 3 | Quote:
12-17-2021, 15:24 | #100 (permalink) |
Freak Poster Join Date: May 2017 Age: 27
Member: 2712640 Status: Offline Thanks Meter: 14 | Printing phone history Get Info 17/12/2021 1:56 pm Write Cert 16/12/2021 8:14 am Write Cert 16/12/2021 7:57 am Read Cert 15/12/2021 4:56 pm Read Cert 15/12/2021 4:50 pm Reading certificate... Rebooting phone to factory mode Changing to factory mode Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Failed to flash the eRecovery file, falling back to manual reboot. Please put the phone into factory mode via Test Point! Or do an USB firmware update with a firmware version that is equal or not much older than the one currently on the phone. If you used Test Point to switch into factory mode, you should immediately reconnect your phone's battery as soon as the program detects the device. We counld't identify the device, please select manually, if present! We counld't identify the device, please select manually, if present! Uploading data... Uploading data... Uploading data... Uploading data... Failed to read, try to hard-reset the phone Finished at local time: [12.16.21 21:53:00] WorkID: 162485522 |
12-19-2021, 20:06 | #101 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,766 | reply Dear User, Please reinstall the chimera tool drivers firstly. Then try to do the process again. But make sure that you brick the device when the tool is asking you for it. Best regards Sab Chimera Team Quote:
