10-24-2017, 20:31 | #1 (permalink) |
No Life Poster Join Date: Jul 2011 Location: montreal
Member: 1612872 Status: Offline Sonork: 1613495 Thanks Meter: 178 | frp A520w 2017-10-23 19:31:14 SW Change 2017-10-22 16:41:03 SW Change 2017-10-22 15:41:33 SW Change 2017-10-22 15:39:42 SW Change 2017-10-18 21:15:11 [Reset FRP lock started] Selected model: SM-A520W Checking boot image... Present. Flashing boot image... Downloading boot image. Be patient! Do NOT disconnect the phone! Checking downloaded image. Flashing boot image. After reboot, if the boot process get stuck, you can install a stock firmware. Flashing firmware... Waiting for download mode. Connecting. SBL Info: Model: SM-A520W, Region: CAN, Provider: OPEN, PDA: A520WVLU1AQE3 Reading PIT. Checking firmware compatibility. RP SWREV: B:1 K:0 S:0 The firmware version is compatible. Flashing boot.img Restarting phone. Waiting for device. Be patient! Do NOT disconnect the phone! Device unavailable. Finished at local time: [10.24.17 15:20:28] WorkID: 28283635 --------------------------------------------------------------------- the cell is always connected with the cable |
10-24-2017, 21:39 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Dear Sir! To have a satisfactory result, please use this firmware: A520WVLU1AQB9 6.0.1 27.02.2017 You can have this firmware dated before March 2017 in the chimera support or here: https://samsung-firmware.org/downloa...A520WOYA1AQB9/ The combination option offered by chimera is: A520WVLU1AQC1 03/2017 |
10-25-2017, 19:10 | #3 (permalink) | |
Member: 1612872 Status: Offline Sonork: 1613495 Thanks Meter: 178 | Quote:
10-26-2017, 00:31 | #4 (permalink) |
Member: 1612872 Status: Offline Sonork: 1613495 Thanks Meter: 178 | Printing phone history SW Change 2017-10-25 23:17:27 Reset FRP Lock 2017-10-25 18:07:17 SW Change 2017-10-24 23:12:25 SW Change 2017-10-24 22:16:41 Reset FRP Lock 2017-10-24 19:17:08 [Reset FRP lock started] Selected model: SM-A520W Checking boot image... Present. Flashing boot image... Flashing boot image. After reboot, if the boot process get stuck, you can install a stock firmware. Flashing firmware... Waiting for download mode. Connecting. SBL Info: Model: SM-A520W, Region: CAN, Provider: OPEN, PDA: A520WVLU1AQB9 Reading PIT. Checking firmware compatibility. RP SWREV: B:1 K:0 S:0 The firmware version is compatible. Flashing boot.img Restarting phone. Waiting for device. Be patient! Do NOT disconnect the phone! Device unavailable. Finished at local time: [10.25.17 19:29:34] WorkID: 28344235 |
12-01-2017, 22:25 | #6 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Canada
Member: 219362 Status: Offline Thanks Meter: 31 | I tried this as well and it's another failed FRP! Chimera FRP is not working well, if at all. Chimera Mobile Phone Utility version: 15.83.1325 @ 2017-12-01 Printing phone history Reset FRP Lock 01/12/2017 9:14:16 PM SW Change 01/12/2017 8:52:11 PM Reset FRP Lock 01/12/2017 8:47:14 PM SW Change 30/11/2017 9:40:20 PM Reset FRP/Reactivation Lock - UFS 30/11/2017 9:35:08 PM [Reset FRP lock started] Selected model: SM-A520W Checking boot image... Present. Flashing boot image... Flashing boot image. After reboot, if the boot process get stuck, you can install a stock firmware. Flashing firmware... Waiting for download mode. Connecting. SBL Info: Model: SM-A520W, Region: CAN, Provider: OPEN, PDA: A520WVLU1AQB9 Reading PIT from phone. Checking firmware compatibility. RP SWREV: B:1 K:0 S:0 The firmware version is compatible. Flashing boot.img Restarting phone. Waiting for device. Be patient! Do NOT disconnect the phone! Device unavailable. Finished at local time: [12.01.17 13:21:03] WorkID: 29973220 Quote:
12-01-2017, 22:53 | #7 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | The combination option offered by chimera is: A520WVLU1AQC1 03/2017 Please, use this Combination File: COMBINATION_OYA_FA60_A520WVLU1AQC1.zip https://androidfilehost.com/?fid=673368273298988366 1. Flash with combination file 2. The phone will start in the engineering menu and there will be communication adb Go to the menu and open the development option 3. Open chimera and choose the Reset FRP Lock New option 4. Once it finishes go to the menu of the phone and make an delete from the menu 5. Connect to chimera 6. Flash with the latest firmware version |
12-07-2017, 20:31 | #8 (permalink) | |
your solution it works | |
07-25-2018, 00:42 | #11 (permalink) |
Member: 1612872 Status: Offline Sonork: 1613495 Thanks Meter: 178 | [Reset FRP lock started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-A520W Timezone: America/St_Johns Android Version: 6.0.1 [MMB29K] [SDK 23] Build Date: Mon Jan 15 19:24:46 KST 2018 PDA Version: FA60_A520WVLU2ARA1 Phone Version: A520WVLU2ARA1 [january 2018, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON325 Serial Number: R58JB31FDSD Imei: 35522708820431 Battery Status: 4.16V (87%) Network Type: GSM SIM Status: READY Multisim Config: SS Knox Version: v00 Warranty Bit: 0 Security Patch: 2016-12-01 Data Encryption State: unencrypted Processing...  To avoid any problems caused by the combination boot, please install a stock firmware. To complete FRP Reset goto "Backup and reset" and select "Factory data reset". Succeeded. Finished successfully. Finished at local time: [07.24.18 19:36:39] WorkID: 41329408 ------------------------------------------------------------ no solution yet |
07-25-2018, 10:52 | #12 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,741 | reply Hi, could you write me some more information about your case? When I see the process successfully done. Best regards Nicole Quote:
