03-18-2018, 00:23 | #1 (permalink) |
Major Poster Join Date: Jul 2015
Member: 2420796 Status: Offline Sonork: sn4k3r Thanks Meter: 0 | Frp j710 binary 4 - j710fxxu4bql3_ojk4bql3 J710FXXU4BQL3_OJK4BQL3_Repair_Firmware_4Files . I tryed combination and other, but not work nothing. Can you help me ? i Have chimera tools thx in advance |
03-18-2018, 13:52 | #2 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
You can use this binary combination file: 4 COMBINATION_OXA_FA60_J710FXXU4BRA1.rar https://androidfilehost.com/?fid=746010030569952678 After making flash, the phone will open in engineer mode. 1. Connect to chimera 2. Make FRP Reset Lock New 3. Then enable the development options and make a manual deletion from the menu of the phone 4. Flash with the latest version of the firmware of your model. | |
03-19-2018, 11:10 | #4 (permalink) | |
Dear Sir! Once you have done flash with the engineering file and have done the FRP with chimera, the phone will be in the engineering menu. Enter the menu and make a manual deletion from the menu of the phone. Then he does the flash with the latest version of the firmware. | |
03-19-2018, 15:13 | #6 (permalink) | |
https://www.youtube.com/watch?v=9LkLxNHsvTs | |
03-19-2018, 15:42 | #7 (permalink) |
Member: 2420796 Status: Offline Sonork: sn4k3r Thanks Meter: 0 | i tryed your guide, but not work... 1. flashed combination (BRA1) 2. frp removed with chimera 3. factory data reset from menu of combination 4. reflash stock rom and ever frp lock -.-' |
03-19-2018, 16:09 | #8 (permalink) | |
1. Flash Combination The phone will start in the engineering menu and adb communication will be enabled but it is not necessary to use the FRP function 2. In these cases and to ensure that you have to enable usb debugging and do a manual deletion and when you re-start the engineering menu, perform the activation of the development options again before doing flash Ideally, you can see the OEM option unlock. But, it does not matter and continue with the process. 3. Download from the support the firmware of 4 files in each folder and only check these options: A) BOOT - (check sboot) B) PDA - (tick Boot, Recovery, System) C) PHONE - DO NOT tick anything or load D) CSC - DO NOT tick or load The phone will start without an account, enable usb debugging and now you can see and enable OEM Unlock. Then they do a manual deletion and the phone is re-initiated without an account. Method 2: Once the FRP is successful, using these commands in a CMD window you should see the OEM unlock to do a manual deletion. 1- adb devices 2- adb shell netcfg 3- adb shell content insert --uri content: // settings / secure --bind name: s: user_setup_complete --bind value: s: 1 4- adb shell content insert --uri content: // settings / secure --bind name: s: user_setup_complete --bind value: s: 1 | |
The Following 3 Users Say Thank You to gcceleghg For This Useful Post: |
03-20-2018, 00:29 | #10 (permalink) |
Member: 2420796 Status: Offline Sonork: sn4k3r Thanks Meter: 0 | other question.. i can use this command for enable in the developer menu of engineer combination "OEM Unlock" and unlock frp, for all samsung ? Marshmallow and nougat ? 1- adb devices 2- adb shell netcfg 3- adb shell content insert --uri content: // settings / secure --bind name: s: user_setup_complete --bind value: s: 1 4- adb shell content insert --uri content: // settings / secure --bind name: s: user_setup_complete --bind value: s: 1 |
03-20-2018, 18:08 | #11 (permalink) |
Member: 2420796 Status: Offline Sonork: sn4k3r Thanks Meter: 0 | with the command adb devices i see devices attached, when i send this command : adb shell netcfg , i have this reply "/system/bin/sh: netcfg: not found" why this error ? -.-' |
