05-03-2018, 13:16 | #5 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote: Unfortunately the image can not be seen then you can not know which model of G920 you have to remove the samsung account. You could use these two functions but binary: 5 is not supported. Reset Reactivation Lock Reset FRP / Reactivation Lock - UFS Try using a combination file with binary: 5 and in normal mode use the Reset Reactivation Lock function | |
05-03-2018, 19:42 | #6 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Romania Age: 37
Member: 120579 Status: Offline Thanks Meter: 182 | Tried UFS, normal Reset frp/ reactivation Including combination COMBINATION_OXA_FA50_G920FXXU5APK1_OXA5APK1_CL6658 768_QB11509139_REV02_user_mid_noship.tar.md5 Nothing works. |
05-03-2018, 20:03 | #7 (permalink) | |
Could I upload the logo and operation made with chimera to this post? Did the operation in normal mode or in download mode? For a complete reset do not forget to do a manual deletion from the menu of the phone Thank you! | |
05-04-2018, 10:44 | #8 (permalink) |
Member: 120579 Status: Offline Thanks Meter: 182 | Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G920F Sales Code: DDE Country Code: Germany Timezone: Europe/Bucharest Android Version: 6.0.1 [MMB29K] [SDK 23] Build Date: Fri Jan 13 12:35:26 KST 2017 PDA Version: G920FXXS5DQA1 [january 2017, rev1] Phone Version: G920FXXU5DPL4 [december 2016, rev4] CSC Version: G920FDDX5DPL1 [december 2016, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON333 Serial Number: RF8G504F8KM Imei: 359845068859318 Battery Status: 4.11V (69%) Network Type: GSM SIM Status: ABSENT Knox Version: v30 Warranty Bit: 0 Security Patch: 2017-01-01 Data Encryption State: unencrypted Resetting R/L by engineering boot based method. Processing... Processing. Be patient! Do NOT disconnect the phone! After reboot if the boot process get stuck, you can install a stock firmware. Checking custom root image... Downloading custom root image. Be patient! Do NOT disconnect the phone! Checking downloaded image. Present. Rooting by custom image based root method... Flashing firmware... Switching to download mode. Waiting for download mode. Connecting. SBL Info: Model: SM-G920F, Region: EUR, Provider: OPEN, PDA: G920FXXS5DQA1 Reading PIT from phone. Flashing boot.img Firmware flash failed. Finished at local time: [05.04.18 12:44:06] WorkID: 37241227 |
05-04-2018, 17:20 | #10 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Please, follow these steps: 1. Flash combination file binary: 5 2. Open usb debugging Open CMD in windows and run the following commands to see if you can see in the OEM Unlock menu: 1- adb devices 2- adb shell netcfg 3- adb shell content insert --uri content: // settings / secure --bind name: s: user_setup_complete --bind value: s: 1 Once you run these commands, check if you have the OEM Unlock option. If you have it enabled and make a manual deletion from the menu of the phone. If this option has not appeared, and you continue with the combination firmware, use the Chimera Reset Reactivation Lock option in normal mode. After it finishes and restarts, make a manual deletion from the menu of the phone. Very important to return to the original firmware !!!!! Do flash as follows: A) BOOT - (check sboot) B) PDA - (tick Boot, Recovery, System) C) PHONE - DO NOT tick anything or load D) CSC - DO NOT tick or load |
05-05-2018, 12:21 | #12 (permalink) | |
Here Sir: https://easy-firmware.com/home/brows...oship.tar.rar/ | |
05-05-2018, 17:16 | #14 (permalink) |
Member: 120579 Status: Offline Thanks Meter: 182 | Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G920F Sales Code: DDE Country Code: Germany Timezone: Europe/Bucharest Android Version: 6.0.1 [MMB29K] [SDK 23] Build Date: Fri Jan 13 12:35:26 KST 2017 PDA Version: G920FXXS5DQA1 [january 2017, rev1] Phone Version: G920FXXU5DPL4 [december 2016, rev4] CSC Version: G920FDDX5DPL1 [december 2016, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON333 Serial Number: RF8G504F8KM Imei: 359845068859318 Battery Status: 4.18V (73%) Network Type: GSM SIM Status: ABSENT Knox Version: v30 Warranty Bit: 0 Security Patch: 2017-01-01 Data Encryption State: unencrypted Processing... Switching to download mode. Waiting for download mode. Connecting. Initializing. Reading PIT. 1. Disconnect micro USB cable 2. Connect micro UART cable 3. Click OK button.  1. Press and Hold Volume-Down Button 2. Press and Hold Power Button for 10-20 seconds The program will indicate when you can release the buttons. Serial port init failed. Finished at local time: [05.05.18 19:15:17] WorkID: 37312158 |
