11-15-2017, 00:07 | #1 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 36
Member: 199814 Status: Offline Thanks Meter: 1,960 | G920W8 null imie unknown baseband Quote:
null imie or baseband can i reset efs with any trick | |
11-15-2017, 12:38 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Dear Sir! Here I leave the supported functions for this model. Samsung Galaxy S6 SM-G920W8 Read Codes Repair IMEI SW Change Unlock Device Info Firmware Compatibility Info Patch Certificate Read / Write certificate Reboot Repair Device Root Key Reset FRP Lock Reset FRP / Reactivation Lock Reset FRP / Reactivation Lock - UFS Reset Reactivation Lock Reset Screen Lock Restore / Store backup Root / Unroot If the phone has Imei null and does not have a baseband then you can not repair it and you can not write a certificate either. First repair the EFS folder. If you do not have any tool that has this function, you could do the following: 1. Flash the phone using s / n 2. Flash the phone with a combination file a. Root b. Root explorer c. Delete the files that are inside the EFS folder d. Re start the phone |
The Following User Says Thank You to gcceleghg For This Useful Post: |
