11-13-2017, 17:28 | #1 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2692308 Status: Offline Thanks Meter: 0 | G930F G930FXXU1AXXX FRP Fail I have read through all the posts regarding G930F FRP Reset but I'm still not having any success. I have flashed G930FXXU1APB6 have then tried Reset FRP New APB6 02/2016 After flashing APB6 02/2016 the phone restarts, stuck on Samsung screen. Please help! |
11-13-2017, 19:18 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | First put the phone in recovery mode and in the second line you can see what firmware you have into the phone. Then: Flash it with this firmware G930FUAX1XXXX like this, to remove FRP. To make FRP with the model G930F you have the following options: APB4 02/2016 APC6 03/2016 APG2 07/2016 APG3 07/2016 APH2 08/2016 APH1 09/2016 API2 09/2016 |
11-14-2017, 09:35 | #3 (permalink) |
Freak Poster Join Date: Apr 2017 Location: EARTH
Member: 2707419 Status: Offline Sonork: 100.650600 Thanks Meter: 82 | I don't what's happening on chimera thete frp method will always lead to bootloop your phone it's happened to more than 4 times Sent from my SM-J320F using Tapatalk |
11-14-2017, 12:54 | #4 (permalink) | |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
https://androidfilehost.com/?fid=529152257862696217 2. Once you start the phone you will do it in the engineering menu 3. Make sure the ADB communication is ok 4. Connect the phone in normal mode to chimera and make Reset FRP Lock New 5. Once it finishes go to the menu of the phone, mark usb debugging and OEM unlock and make an erasure of the manual phone from the menu 6. When re start, please mark debug usb and OEM unlock, connect the phone to chimera and install the latest version of the firmware. | |
