10-24-2016, 15:55 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Romania,Buc
Member: 694535 Status: Offline Thanks Meter: 70 | g930f unlock failed Chimera Mobile Phone Utility version: 11.77.1721 @ 2016-10-24 [Unlock phone started] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G930F Sales Code: CNX Country Code: Romania Timezone: Europe/Bucharest Android Version: 6.0.1 [MMB29K] Build Date: Tue Aug 9 18:46:20 KST 2016 PDA Version: G930FXXU1BPH6 [august 2016, rev6] Phone Version: G930FXXU1BPH1 [august 2016, rev1] CSC Version: G930FVFG1BPH2 [august 2016, rev2] Product Code: SM2G930FZKACNX HIDSw Version: G930FXXU1BPH6/G930FVFG1BPH2/G930FXXU1BPH1/G930FXXU1BPH6 Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: R58H84SFHWD Imei: xxxxxxxxxxx5669 Unique Number: AD07160310CB1AAB64 Connections: AT,MTP Battery Status: 3.84V (52%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2016-08-01 Unlocking... Please unlock screen if closed. Trying on SAMSUNG Mobile USB Modem (COM85) Processing. Be patient! Do NOT disconnect the phone! Please unlock screen if closed. Try firmware that contains an older modem! Protocol error. Finished at local time: [10.24.16 17:52:42] WorkID: 14465864 solution? |
10-24-2016, 16:18 | #2 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
You are using last firmware, please, use older firnware like this: PDA Version: G930FXXU1APB4 [february 2016, rev4] Phone Version: G930FXXU1APB4 [february 2016, rev4] CSC Version: G930FVFG1APB2 [february 2016, rev2] https://samsung-firmware.org/model/SM-G930F/page/38 See this link: http://forum.gsmhosting.com/vbb/f898...-done-2067287/ | |
10-24-2016, 16:34 | #3 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Online Thanks Meter: 23,741 | reply Dear Sir, install older 6.0.1 version on your device, for example: PDA Version: G930FXXU1APAW [january 2016, 6.0.1] PDA Version: G930FXXU1APB4 [february 2016,6.0.1] PDA Version: G930FXXU1APD3 [april 2016, 6.0.1] PDA Version: G930FXXU1APD1 [april 2016, 6.0.1] PDA Version: G930FXXU1APEQ [may 2016, 6.0.1] PDA Version: G930FXXS1APG3 [july 2016, 6.0.1] if it is done, try again the unlock process. Best regards Nicole Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
10-26-2016, 21:59 | #5 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Its same that. No problem if you want binary:1 Use Odin in CP box CP_G930FXXU1APE9 https://www.androidfilehost.com/?fid=24591000424955934 CP_G930FXXU1APDU https://www.androidfilehost.com/?fid=24591000424955927 CP_G930FXXU1APDN https://www.androidfilehost.com/?fid=24591000424955928 CP_G930FXXU1APD1 https://www.androidfilehost.com/?fid=24591000424955929 CP_G930FXXU1APB4 https://www.androidfilehost.com/?fid=24591000424955926 |
10-27-2016, 21:08 | #6 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2642042 Status: Offline Thanks Meter: 0 | Note y g930f protocol error hi to all! thanks for accept me in this group. I new here and I need some help for unlock my Note 7 model g930f from Claro PR can some body help me with the instruction sent to me a link for change modem or firmware correctly? and instruction. I'm try some ones and don't work. Please help me. I appreciate your help. |
10-27-2016, 22:30 | #8 (permalink) | |
This model is supported by Chimera Tool Model: SM-N930FSupported features ✓ SW Change ✓ Unlock ✓ Info ✓ Root/Unroot ✓ Restore / Store backup ✓ Reset FRP Lock You only use the chimera software and perform the unlocking operation. If you should have any problems, turn up the logo of the operation and work ID and support will give you a help. If you should have this firmware N930FXXU2BPI7, please do not degrade modem firmware or to avoid problems. | |
11-09-2016, 09:03 | #11 (permalink) |
Freak Poster Join Date: Jul 2009
Member: 1075753 Status: Offline Thanks Meter: 66 | I am having an Issue on a S7 ( G930F - 3 -UK ) - G930FXXU1BPH6 I can't flash any firmware, except combination firmware at times. Now the Phone is stuck on Logo. It was flashing upto hidden.IMG now it won't even flash system file. Work ID 14883350 |
11-09-2016, 09:38 | #12 (permalink) |
Member: 1075753 Status: Offline Thanks Meter: 66 | update. I tried to unzip the AP_G930FXXU1APB4_CL7162483_QB8489863_REV00_user_lo w_ship to delete the Hidden.img but there wasn't any hidden.img there were only 3 files boot , recovery and system. |
