03-20-2018, 11:44 | #1 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 362622 Status: Offline Thanks Meter: 43 | G935F flashing problem it had a lock screen before i tried to bypass it without loose datas problem phone stayed on logo after i want flash it normally but error there is log Connecting. SBL Info: Modèle: SM-G935F, Region: EUR, Provider: OPEN, PDA: G935FXXU1APB4 Valid PIT file can be found in the firmware: HERO2LTE_EUR_OPEN_HIDDEN200M.pit Use the "Enable PIT Write" option if you want to use it. Reading PIT from phone. File hidden.img size is larger than specified in the PIT. File hidden.img will be flashed. Checking firmware compatibility. RP SWREV: B:1 K:0 S:0 Upgrade: hidden.img (0 -> 1) Upgrade: cache.img (0 -> 1) The firmware version is compatible. Flashing boot.img Flashing recovery.img Flashing system.img Flashing sboot.bin Flashing param.bin Flashing cm.bin Flashing modem.bin Flashing modem_debug.bin Flashing cache.img Flashing hidden.img It is possible that the data depending on the service-provider (hidden) has not enough space or it is not compatible. Firmware Flash échoué. Finished at local time: [03.20.18 11:32:24] WorkID: 35049231 can you help me please |
03-20-2018, 13:19 | #2 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, wipe device first after try... if you bypass FRP device for third party or just bug need wipe device.... after try flash again.... Best Regards Shensohau |
