02-19-2018, 11:06 | #1 (permalink) |
Freak Poster Join Date: Oct 2012
Member: 1825048 Status: Offline Thanks Meter: 10 | G935F G935FXXU2DRAG [U2] frp Failed Flashing firmware... Waiting for download mode. Connecting. SBL Info: Model: SM-G935F, Region: EUR, Provider: OPEN, PDA: G935FXXU2DRAG Reading PIT from phone. Flashing boot.img Restarting phone. Waiting for device. Be patient! Do NOT disconnect the phone! hang on samsung logo not opened phone how to solved it? |
02-19-2018, 11:35 | #2 (permalink) |
Crazy Poster Join Date: Jan 2012
Member: 1714705 Status: Offline Thanks Meter: 6 | try to flash same version.....phone will live again and by pass fpr z3x ufs method..... https://www.youtube.com/watch?v=MWEcV94ofsE IF YOU LIKE WHAT I POST PRESS THANKS BUTTON |
02-19-2018, 13:06 | #3 (permalink) | |
Member: 1825048 Status: Offline Thanks Meter: 10 | Quote:
Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM3 OK Phone detected, do not release 'Vol down' Reading data from phone... error (2) Done with Samsung Tool PRO v.30.8 | |
02-19-2018, 14:00 | #4 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
02-19-2018, 16:06 | #8 (permalink) |
Member: 1825048 Status: Offline Thanks Meter: 10 | write combination,and reset frp button[Succesfuly] later choosing only boot file AP(nothinguserdata.IMG) and Home CSC and then writing fimware but not remove google account Last edited by the_dai; 02-19-2018 at 16:12. |
02-19-2018, 16:12 | #9 (permalink) | |
Dear Sir! FRP Binary:2 not suppered yet. If you have a combination firmware with binary:2 You have two ways of doing it: Method 1: 1. Flash Combination The phone will start in the engineering menu and adb communication will be enabled but it is not necessary to use the FRP function 2. In these cases and to ensure that you have to enable usb debugging and do a manual deletion and when you re-start the engineering menu, perform the activation of the development options again before doing flash Ideally, you can see the OEM option unlock. But, it does not matter and continue with the process. 3. Download from the support the firmware of 4 files in each folder and only check these options: A) BOOT - (check sboot) B) PDA - (tick Boot, Recovery, System) C) PHONE - DO NOT tick anything or load D) CSC - DO NOT tick or load The phone will start without an account, enable usb debugging and now you can see and enable OEM Unlock. Then they do a manual deletion and the phone is re-initiated without an account. Method 2: Once the FRP is successful, using these commands in a CMD window you should see the OEM unlock to do a manual deletion. 1- adb devices 2- adb shell netcfg 3- adb shell content insert --uri content: // settings / secure --bind name: s: user_setup_complete --bind value: s: 1 4- adb shell content insert --uri content: // settings / secure --bind name: s: user_setup_complete --bind value: s: 1 | |
The Following 4 Users Say Thank You to gcceleghg For This Useful Post: |
02-19-2018, 16:18 | #10 (permalink) | |
Registered User Join Date: Dec 2015 Location: Chittagong, Bangladesh
Member: 2506300 Status: Offline Thanks Meter: 345 | Quote:
today done by me | |
02-19-2018, 16:23 | #12 (permalink) | |
02-19-2018, 16:30 | #15 (permalink) | |
http://forum.gsmhosting.com/vbb/f453...-here-2347468/ | |
