12-14-2018, 17:57 | #1 (permalink) |
No Life Poster Join Date: Aug 2015 Location: KATHMANDU,NEPAL
Member: 2438408 Status: Offline Thanks Meter: 380 | g935f imei repair failed Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G935F Sales Code: ZTR Country Code: Brazil Timezone: Asia/Kathmandu Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Fri Oct 12 13:21:35 KST 2018 PDA Version: G935FXXS3ERJ8 [october 2018, rev8] Phone Version: G935FXXU3ERJ8 [october 2018, rev8] CSC Version: G935FZTR3ERJ1 [october 2018, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: RF8HB18EB3D Imei: 000000000000000 Battery Status: 3.69V (18%) Network Type: GSM SIM Status: READY,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2018-10-01 Data Encryption State: encrypted Repairing IMEI... Reading and storing secure image. Be patient! Do NOT disconnect the phone! Checking secure image. Preparing. Please unlock screen if closed. Reading modem. Be patient! Do NOT disconnect the phone! Calculating. Be patient! Do NOT disconnect the phone! Repair imei failed. Unable to Repair imei Finished at local time: [12.14.18 22:25:37] WorkID: 49251677 |
12-15-2018, 13:14 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Still not supported the binary parch 3 android 8 You can repair Imei but you can not patch the modem and you can not have a signal. You also have another problem: Serial Number: RF8HB18EB3D Imei: 000000000000000 When the Imei is in 35000000 that means that the EFS folder is corrupted and the security of the phone is damaged. If either SW version is unknown, or HW Chip is unknown, or HW Modem is unknown - most likely phone's firmware firmware or EFS is damaged, or you have written unsuitable firmware. Also, this can be HW problem. You should re-flash the device with different firmware one by one and check, if modem is correct (not Unknown). If after writing of all firmwares, which you have, problem remains the same - most likely, this is HW problem (problem with eMMC flash chip). |
The Following User Says Thank You to gcceleghg For This Useful Post: |
