01-11-2020, 13:03 | #1 (permalink) |
Insane Poster Join Date: May 2017 Location: Pakistan,
Member: 2714896 Status: Offline Thanks Meter: 1 | G935F U7 Cert Patch issue Patch Done but Still cert NG Model: SM-G935F Sales Code: XSG Country Code: UAE Timezone: Asia/Karachi Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Thu Dec 19 16:32:08 KST 2019 PDA Version: G935FXXS7ESL6 [december 2019, rev6] Phone Version: G935FXXS7ESL4 [december 2019, rev4] CSC Version: G935FOJV7ESL8 [december 2019, rev8] Product Code: XSG HIDSw Version: G935FXXS7ESL6/G935FOJV7ESL8/G935FXXS7ESL4/G935FXXS7ESL6 Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: RF8H21G50MH Imei: 357329088855053 Unique Number: 9885E63358434F4E5A Connections: AT,MTP Battery Status: 3.67V (4%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2019-12-01 Data Encryption State: encrypted Preparing... Checking root access. The phone is rooted by: 20.2:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [01.11.20 16:51:38] WorkID: 85738426 Patch success Full But Still Ng No network |
01-13-2020, 13:59 | #4 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,746 | When your device's imei status NG after the processes, the reason can be: 1. wrong sequence of the processes 2. root was not completed correctly. That is why I can offer: 1. re-flash your device 2. repair imei or write cert 3. root your device 4. start patch cert process Best regards Nicole |
01-13-2020, 15:08 | #5 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, just use compleate 4 parts firmware, example: ASK4... same version CP,BL,AP,CSC... repeat procedure |
The Following User Says Thank You to Shensohau For This Useful Post: |
01-19-2020, 08:34 | #7 (permalink) |
No Life Poster Join Date: Jan 2010 Location: iraq
Member: 1215266 Status: Offline Thanks Meter: 129 | Chimera Mobile Phone Utility version: 23.59.1330 @ 2020-01-19 Printing phone history Patch Certificate 1/19/2020 7:02:48 AM Patch Certificate 1/19/2020 7:01:59 AM Patch Certificate 1/19/2020 6:57:21 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G935F Sales Code: MID Country Code: Iraq Timezone: Asia/Baghdad Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Thu Dec 19 16:32:08 KST 2019 PDA Version: G935FXXS7ESL6 [december 2019, rev6] Phone Version: G935FXXS7ESL4 [december 2019, rev4] CSC Version: G935FOJV7ESL8 [december 2019, rev8] Board Platform: EXYNOS5 Modem Platform: SHANNON335 Serial Number: R58HC142CEA Imei: 354737081770199 Battery Status: 3.91V (58%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-12-01 Data Encryption State: unencrypted Preparing... Checking root access. The phone is rooted by: 16.0:MAGISKSU (topjohnwu) Previously installed patchcert detected. Previously installed patchcert successfully removed. Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [01.19.20 10:33:24] WorkID: 86538004 SAME PROBLEM |
