08-22-2017, 21:54 | #2 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
Follow these instructions 1. Disconnect micro USB cable 2. On dial window enter * # 0 * # 3. Connect micro UART cable 4. Wait a few seconds 5. Click OK button Samsung Galaxy S8 SM-G950F Features SW Change Device Info Firmware Compatibility Info MSL Unlock Reboot Root / Unroot | |
08-22-2017, 21:59 | #4 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Dear user! The UART cable is required to perform this operation. Try to do the operation with any UART cable and upload to this post the result. With the phone turned on, do the following: 1. Enable debugging usb and OEM unlock 2. Aso, the MTP connection Then go to device manager in windows (right mouse button and click on the windows window) if you can see the phone connected to the PC If you do not see your device, you need to update the connection driver. If you have a connection to the PC and Chimera can see the device, start the process and when you ask for the UART cable, do the following: 1. Phone must be powered on. 2. Run dialer and type * # 0 * # (service mode will apear). 3. Connect to UART cable (See the conection OK) 4. Press 'Unlock' button. |
