09-18-2019, 13:40 | #1 (permalink) |
Junior Member Join Date: Sep 2019 Location: EU
Member: 2928151 Status: Offline Thanks Meter: 0 | G955F Emergency calls after successful patch cert I really dont know how to properly troubleshoot this. Printing phone history Knoxguard Unlock 16.09.2019 05:52:59 Knoxguard Unlock 16.09.2019 05:51:00 Knoxguard Unlock 16.09.2019 05:49:41 Patch Certificate 16.09.2019 05:34:49 Patch Certificate 16.09.2019 04:47:35 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G955F Sales Code: SEB Country Code: BALTIC Timezone: Europe/Riga Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Fri Aug 23 19:02:59 KST 2019 PDA Version: G955FXXU5DSHC [august 2019, revC] Phone Version: G955FXXU5ASF1 [june 2019, rev1] CSC Version: G955FOXM5DSHC [august 2019, revC] Product Code: SEB HIDSw Version: G955FXXU5DSHC/G955FOXM5DSHC/G955FXXU5ASF1/G955FXXU5DSHC Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: R58J463YNZN Imei: 358792082493669 Unique Number: CE031713EDAAAB3002 Connections: AT,MTP Battery Status: 3.85V (40%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-08-01 Data Encryption State: unencrypted Preparing... Checking current patchcert. Checking modem. Checking root. The phone is rooted by: 19.3:MAGISKSU Checking boot image. Be patient! Do NOT disconnect the phone! The knox is still valid. Because of the boot patch the warranty will void. Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... The operation is in progress. Be patient! Do NOT disconnect the phone! After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [09.16.19 08:57:52] WorkID: 73267159 |
09-18-2019, 14:38 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Hi, hmm.. try to re-flash your device and root then start again the repair process and patch cert finally. I think when it is SW side issue problem will be solved with it. Best regards Nicole Quote:
09-23-2019, 09:12 | #5 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Hi, basically it is not important by that case, just re-flash your device and start again the root and repair finally patch cert processes. Best regards Nicole |
