05-25-2019, 15:54 | #1 (permalink) |
Freak Poster Join Date: Feb 2018 Location: Zimbabwe
Member: 2807070 Status: Offline Sonork: 550000 Thanks Meter: 37 | g965f camera not working i rooted device g960f method can any one know what is the problem |
The Following User Says Thank You to hasheemkapla559 For This Useful Post: |
05-31-2019, 18:41 | #4 (permalink) |
No Life Poster Join Date: Aug 2015 Location: KATHMANDU,NEPAL
Member: 2438408 Status: Offline Thanks Meter: 380 | i have same problem ?? i need root for patch imei patch imei done but front camera not working . i flashed phone camera working but network not working any solution ??? |
05-31-2019, 23:43 | #5 (permalink) |
Freak Poster Join Date: Nov 2004 Age: 42
Member: 91740 Status: Offline Thanks Meter: 31 | i have same problem ?? i need root for patch imei patch imei done but front camera not working . i flashed phone camera working but network not working any solution ??? |
06-01-2019, 01:31 | #6 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 952912 Status: Offline Thanks Meter: 142 | Check if the camera is working after flaahing the custom kernel/boot. Before patch cert. It is likely due to kernel/boot img, and not patch cert. In this case, you can attempt different root methods, with stock boot. |
06-01-2019, 13:31 | #10 (permalink) |
Member: 91740 Status: Offline Thanks Meter: 31 | - make a KnoxGuard Unlock with ChimeraTool - flash "twrp-3.3.1-0-starlte.img.tar" with ChimeraTool. make sure the "Skip Auto Reboot" option is selected - restart your phone in recovery mode: press and hold bixby + volume_down + power, when the display darkens immediately press and hold volume_up (do not release bixby + power) - twrp: wipe: Format Data (type yes) - twrp: install: ElementalX-S9-2.06.zip - twrp: install: no-verity-opt-encrypt-6.0.zip - twrp: install: RMM-State_Bypass_Mesa_v2.zip - twrp: install: Magisk-v19.2.zip - twrp: wipe: Advanced Wipe: wipe data, cache and dalvik/art cache - twrp: reboot: system - install MagiskManager (adb install -r MagiskManager-v7.2.0.apk) - MagiskManager: Settings/Superuser: Automatic response: grant twrp-3.3.1-0-starlte.img.tar NEW ElementalX-S9-2.06.zip NEW Magisk-v19.2.zip NEW MagiskManager-v7.2.0.apk NEW https://dl.twrp.me/starlte/twrp-3.3....e.img.tar.html https://magiskmanager.com/downloading-magisk-manager https://androidfilehost.com/?fid=1395089523397970571 Last edited by CEPHASTANESİ; 06-01-2019 at 13:40. |
The Following 4 Users Say Thank You to CEPHASTANESİ For This Useful Post: |
07-18-2019, 19:58 | #11 (permalink) | |
Member: 2438408 Status: Offline Thanks Meter: 380 | Quote:
