04-22-2020, 07:59 | #1 (permalink) |
Junior Member Join Date: Mar 2020 Location: Australia
Member: 2952039 Status: Offline Thanks Meter: 2 | G970F XXU4CTC9_Q cannot flash any rooted AP Edit: Always correctly rename your patched images Last edited by ShowbizWR; 04-22-2020 at 08:27. Reason: Solved |
04-22-2020, 10:48 | #3 (permalink) |
Member: 2952039 Status: Offline Thanks Meter: 2 | Yes ... I think I'm getting the sequence wrong .. flashing stock with Odin .. repair IMEI... Root .. cert patch? .... After I return to stock and repair IMEI I'm unable to flash patched magisk tar in Odin to complete cert patch process pls help Sent from my F2 using Tapatalk |
04-22-2020, 10:52 | #4 (permalink) |
Member: 2952039 Status: Offline Thanks Meter: 2 | I can flash magisk patched AP in Odin . Seems after I repair IMEI in Chimera something trips Knox .. I'm hoping it's just me getting something wrong Sent from my F2 using Tapatalk |
04-23-2020, 08:58 | #5 (permalink) |
Member: 2952039 Status: Offline Thanks Meter: 2 | Ok so I have realised I needed wifi to stop tripping knox I am still having abit of trouble I will try explain my steps .. I start with Odin flashed stock firmware I then repair IMEI (without root) IMEI repair is successful.. I flash magisk patched AP and then patch cert successfully.. shouldn't that be the right process? When I reboot there is still no network but IMEI is changed Worst thing is I patched this g970f last week and now have messed it upHELP . Hope everyone is coping well btw ... Sent from my F2 using Tapatalk |
04-23-2020, 10:38 | #6 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,746 | reply Hi, please send us the work id of the patch cert process and we can check your case. Best regards Nicole Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
04-23-2020, 11:59 | #7 (permalink) |
Member: 2952039 Status: Offline Thanks Meter: 2 | I started with WID 93817226 flashing stock , then WID 93818800 for the IMEI repair then WID 93818982 flashing magisk patched AP .... Then WID 93820017 for patch cert .. ?? Please help Sent from my F2 using Tapatalk |
04-24-2020, 00:49 | #8 (permalink) | |
Member: 2952039 Status: Offline Thanks Meter: 2 | Quote:
Sent from my F2 using Tapatalk | |
04-24-2020, 00:51 | #9 (permalink) |
Member: 2952039 Status: Offline Thanks Meter: 2 | All were successful flashes . Yet IMEI is not network patched? What am I doing wrong please .Ive followed your steps multiple times to exact order ... Sent from my F2 using Tapatalk |
